Question about Kenmore 16372 / 16374 / 16379 Built-in Dishwasher
Kenmore touchpads Yes, please kindly provide me the link for replacing Kenmore touchpads. Are they easy to replace by the average person without a lot of mechanical aptitude?
  • 4,889 Answers
You can find it on Appliance Parts.com, Appliance Pros.com Discount Appliance Parts and Appliance Repair Parts.
The model you included isn't actually the model number. The data tag is somewhere near the door gasket, so include that for sure so that i can directly guide you to the purchase zone..
Posted on Mar 13, 2008
SOURCE:
My kenmore microwave just stopped working after less that 3 years and not a lot of use. No power of any kind and outlet works. Can I fix it?
Hello there and welcome to fixya
Normally on these units it is the fuse that sits on the mother board that is inside of the oven it is a easy replaceable part so i would say yes you should be able to do this all you will have to do is first unplug the oven then remove all of the screws that are on the leading edge of the back and the sides then the cover will slide back about 2 inches or less then lift off the small electronics board will be located on the inside towards the front behind the touchpad you shouldnt miss it
just look now for the glass fuse and remove it and go to radio shack orwalmart a automobile parts center like autozone and they should have this tiny fuse it should be about 4 dollars ok
Hope this all helps and good luck with the repairs please let me know if you need any more help i can continue to help if needed
Best regards Mike
Sep 12, 2011 | Microwave Ovens
Coil Packs keep on blowing replaced them and the car won't start. Someone told me the engine harness may have to change! Please help :(
Why would a wiring harness have to be changed
We get more screw ball questions here
Use common sense. Why would a wiring harness
just go bad or wear out ,there wires.
Could the harness been mishandled several times
by mechanics. Yes
Half of all problems are put into vehicles, due to
sloppy work and inexperience
All you need to do,is go to a repair shop with a
reputation of solving your kind of issues
You need to research a repair shop before you need
one,not when your broken down
No one can answer your question. Your car has to be
properly tested. So spend a lot of time explaining what you
want checked out & don't leave any car without a road
test in which you and a mechanic go on
Also,you only authorize work in person,not over the phone,
so plan on going to the shop a couple of times.
All work to be done is put on a repair order you read
and approve,before any work is done
Apr 24, 2011 | Mitsubishi Lancer Cars & Trucks
F1 is popping up on my digital display and a beeping noise comes along with it. What does that mean and how do I get it to stop?
Your F1 error is
: indicating an electronic control malfunction
: (a $250 part) or a control panel (a $60
: part)? Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control panel (without the electronic control) but on some models the keypad linked below can be used to repair the one on the original control panel.
Apr 19, 2010 | Magic Chef 9122 Gas Single Oven
Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
My Inspiron 9300 touchpad needs replacing
This is not a do it yourself repair, best sent to repair shop or back to factory to have it replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Oct 28, 2009 | Dell Inspiron 9300 Notebook
Can I replace the touchpad?
Yes, though replacing the whole keyboard is actually less expensive than buying the touchpad alone. It's really pretty easy, and there are several replacement keyboards online- ebay and TigerDirect.com are great resources for replacement parts
Sep 24, 2009 | HP Compaq nx9600 Notebook
Replace stk392 on panasonic tv
yes.u can easily replace the stk ic.but you should be perfect in soldering the ic.thats the main thing necessary in replacing the ic. to get the full instructions step by step with diagrams just click this link and follow http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
please do rate the solution . thanks.
Feb 09, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Replace driver's side door hdle & locking mechanism on 02 Protege
Removing the door skins are not hard, the problem is that they normally use a special tool. Without the tool you may break a few of the plastic clips. If so no worries go to your local automotive department and look for the clips.
You will also have at least one screw that attaches the skin to the door frame. Usually remove the bottom of door panel and work around both sides until you get to the window. Then remove the screw and unplug any of the power options..
Haynes or  Chiltion manual for your car should show you details.. It is easy for the average DIY person.
The handle is just as easy. Do you have metric and torx because you will need them.
Dec 03, 2008 | 2002 Mazda Protege
Kenmore dishwasher touchpads
Yes you can surely do it yourself..its just unplugging a few wires remove the old one and just install the new one..
I couldn't find the model number you have specified, but you can give these guys a call and specify ask for a new touchpad for kenmore 16372. They will ship it out for you.. I advise you call their toll free number that you can find on their site so that you can get it done real quick.. http://www.laundryparts.com/sunshop/index.php?action=category&id=bestsellers
Mar 14, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
142 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
