Question about Canon EOS 400D / Rebel XTi Digital Camera
Color resolution problem
Hi there, I owned EOS 400D, when I have edit the pict in RAW processing.
after I saved the pict as jpeg/jpg, I got a problem with the resolution,
I rotate the pict 180 degree..and the result is the color is getting sharp and hard...its still same even if I save in RAW or JPG...
any suggestion....??? thank you
doy
indonesia
  • 111 Answers
Select a lower value for image saturation in camera menu settings. Then you can adjust in raw processing if saturation is too low. This may apply to in-camera setting for image sharpness as well. In general, use conservative settings in camera, then if anything needs adjusting do this in raw processing stage.
Posted on May 15, 2008
On my Rebel Canon t2i how do I change the images from RAW to JPEG?
when you have an image from raw, for example 3000 x 4000 pixels, and convert to jpg , it remains 3000 x 4000 pixels, so detail remains the same, but you have make sure compression is 100% 10 or 12 scale when save as export , in options, if you lower compression the pixelating becomes noticeable,
http://www.selteco.com/support/s1065.php
http://graphicssoft.about.com/od/formats...
check settings for save as export for photoshop and lightroom, keep resolution high, if images are resized to smaller 5x7 " sizes for web, maintain resolution ratio from 72 up towards 300 ppi/dpi,
Save as copy, not save for web,
http://help.adobe.com/en_US/Photoshop/11...
if you were saving to limited web service site, they may decompression or lower file size quality of original image for upload,
if you have lower bandwidth service, your settings for web use may also be low for faster loading, making quality lower,
Canon Rebel T3i / EOS 600D 18mp
http://usa.canon.com/cusa/consumer/produ...
http://www.canon.co.uk/For_Home/Product_...
Aug 20, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
Raw Format Ooops
hi there,
you can use a memory card reader, if your camera software was faulty to use..
Thank you
May 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Delete button not working ( Canon EOS 400D )
1) Put lens or camera cap on, go to a dark room to be sure if you want
2) Take JPG+RAW shot, maybe at different ISO and shutter speeds, one could be 30 sec/ISO 1600
3) Press menu, go to Settings 2 tab, and press sensor Cleaning: Manual, then OK. Wait for 30 seconds or more (is this necessary?) The mirror inside opens, but since you are not removing dust, this has really no effect, but it seems that after doing this, the camera remaps the dead pixels.
4) Take another JPG+RAW shot, compare with shots from 2) - same shutter and ISO
Aug 04, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
How do i save raw pictures from my camera to a disk. When I transfer them to my computer I can only open them with my cameras software. I don't know how to get them into another program so I can burn them....
You can't burn raw pictures. They are only data from a camera....not an actual picture. They must be processed in an editing program and then converted to another format such as jpeg or tiff.
Apr 25, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I cannot get RAW file from my 1000D. It only save jpeg.
You need to have software on your computer to process the raw files. Your camera probably came with a software CD or you may have a program on your computer such as Photoshop Elements that can process the raw files.
Nov 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
A list and defintion of the file types raw b, raw, fine, norm and basic
The D3000 can store still images in two different formats. JPEG is a standard format, recognized by just about every image viewer and image manipulation program in the world. RAW is actually NEF (Nikon Electronic Format), a Nikon-proprietary format which incorporates almost all of the data captured by the sensor, without the processing of JPEG. JPEG files have the color balance, sharpening, contrast, and all the other camera settings done on the picture. With RAW files, you can change any or all of them and produce new JPEGs. In this respect the RAW file is similar to the original negative you get from processed film, while the JPEG file is like the final print. RAW files need special software for viewing and editing.
All JPEG files are compressed to save space. FINE, NORM, and BASIC represent different levels of compression. FINE does the least compression and takes up the most space, BASIC does the most compression and takes up the least space. Compression always loses some quality, so in general the less the compression the better the quality.
RAW+B simply stores each of your pictures as a RAW file and a BASIC JPEG file.
Having said all that, you should use only RAW or FINE settings. You didn't buy a SLR only to throw away picture quality, did you?
Oct 25, 2010 | Nikon D3000 Digital Camera
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
EOS 400D Digital Camera Software
Hi
If you bought your camera (400D) new it would have come with RAW conversion software on a disk. You can start by installing this. To get the photos off the camera you should be able to plug it in vis the USB cable that came with it. The better way would be to buy a card reader. This is a lot quicker, save on battery wear and tear, or save you plugging in the power.
Alternative software would be to buy Adobe Photoshop Elements for the RAW processing. This is a good start for most people.
Regards
Jul 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Choosing to shoot Raw images
If you have Rebel XTi (400D), press Menu button.
Under the 1st Tab, the first option is "Quality" - select it. You should see 8 options from "fine L" to "Raw". Move selection using the arrow keys, and select RAW.
Mar 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Canon EOS 400D / Rebel XTi Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
