Question about HP Compaq nx5000 Notebook
Compaq nx5000 startup trouble
My HP/Compaq nx5000 won`t start up,With no batt.fixed, I plug powercable in, then processor fan start spining,stops,spins again,stops and so on, untill I pull pow.plug out, nothing else happens.
Kind regards.....Soller.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Atleast you need a dummy battery on it,put the battery on it and check , one more way is remove the ram and fix
Posted on Mar 13, 2008
SOURCE:
Hi i m deepak jain...i got a hp nx5000 laptop...it automatically geting restarted...one blue screen appears with a text begning dump of physical memory.....plz can u help me out??
I think Your Os Was Corrupted So
TO Restore it
On Computer startup Press F8 Key Untill U get the Advance Start up Option There Choose Restore My LAst Setting(I forget actual Line But it was the last option )
And press Enter!!
If all well then your laptop OS will run
Else
Format Your Laptop OS And Reinstall it!!
Regards
Vikas Agrawal
MCA
Feb 07, 2010 | HP Compaq nx5000 Notebook
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
Hp nx 5000 - memory problem
The memory modules are located at the bottom of the laptop under one of the panels.
The memory modules may be OK and may only need reseating. Then boot up the laptop to see if it works, if it doesn't work, the memory may be faulty, take it to a computer shop to get it tested.
Apr 07, 2009 | HP Compaq nx5000 Notebook
No start up
You have to check with some professional because it can be the memory (RAM), the video card, the processor or the charge circuit... so the professional have to test all of that parts...
Jan 22, 2009 | HP Compaq nx5000 Notebook
Compaq nx5000 - will not power up. DIsk spins, green lights for a second , then powers down to only yellow light. SOmetimes - seems after long periods of no use - -powers up and runs. Have sourced new...
I just got my nx5000 up and running again. The memory needed to be reseated in the socket (got this tip of the HP site) All I did was open it up and reseat the ram - just took it out and put it back in again. Problem solved. I also took the opportunity to vacuum a little bit of dust out, but I don't think this was anything to do with the problem.
Get a copy of the service manual (Just google "hp service manual nx5000") it has easy instructions at how to get to the memory - it is just under the keyboard.
Hope this helps!
Dec 10, 2008 | HP Compaq nx5000 Notebook
Not working
remove the ram clean it put it back yor problem will solvs
Aug 04, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000
Here are your drivers
Please vote if you found this information helpful.
Thank You
Apr 18, 2008 | HP Compaq nx5000 Notebook
Startup trouble
fix another ram and check, otherwise it will be the motherboard problem , one more option is remove the harddisk and check
Mar 14, 2008 | HP Compaq nx5000 Notebook
Power problem
The CPU might be overheating because its lose, try to fix it well also check all the other devices if they are firmly fixed.
Mar 06, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
534 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
