Question about Cyberhome CH-DVD 300 DVD Player
No function . Constant orange light that turns red or green depending on which button you press. Won't turn on. Pressing "stop" button does not reset unit as suggestions on other fix-it sites. Comment by 4z4jt, posted on Feb 13, 2008 Srulik.I. Haramaty
  • 4z4jt Mar 22, 2008
    helo
    disconnectig from the mains for 2 days did not solve the problem.
    I shell apriciate more help.
    thans,
    S.H,
  • 4z4jt Apr 17, 2008
    Thanks BENIMUR for your respons.
    No way to turn ON or OFF neither opennig the DISK TRAY.
    The player is complitly dead exept for the LED changing colors.
    Any more idias ??
    Regards,
    Srulik Haramaty -4Z4JT
    Brigadier General:
  • 6,966 Answers
As most current designs of such devices, you can force a full hard reset on the unit/system by unplugging it from the mains for a couple of hours (or overnight).
Thereafter, pls post back if problem persist and will work form thereon.
Posted on Mar 13, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
  • Louie  Role
    Louie Role Mar 23, 2008
    Hi again 4z4jt,
    Could you pls try:
    1. Turn OFF (Standby) the player;
    2. Turn back ON Player;
    3. Open Disc Tray and Press and hold the STOP button on player for 5 Seconds.
  • Louie  Role
    Louie Role Apr 17, 2008
    Hi 4z4jt,
    A couple more to try:
    1. if you can go to Setup/Others/Factory Setting. PW is 3782 and press Enter to reset; or
    2. press FF Search and Skip Prev. on the front control panel (not on the Remote Control) to return to factory settings.
    If it would seem that no external action is corrective of your concern, perhaps it maybe because of an electronic fault within the system.
    As BFixed has responded in your other post, component(s) may be defective. Most DVDs are internally powered by at least two (2) voltages: 12VDC for the motors and 5VDC for the logic circuitry. Based on your other post, you can only read 11.5 & 2.75. The 11.5 would be acceptable but the 2.75 would not be. A you were able to test the voltages, I am assuming that you are familiar with electronics circuitry and components. Please check where the 2.75 came from. It would be normally from a high current regulator, 3 or 5 pins, you need to check the input voltage or simply wing it from there. The voltage should be higher at the input stage and constant/regulated 5VDC. As BFixed suggested, a failed/bulging capacitor in the power supply can cause the voltage to dramatically go low which could probably account for the orange/red/green leds.
    Of course the best would be to have access to a full service manual or at the very least a schematic diagram. Unfortunately, I luck out googling for one. Though I came across a general purpose trouble shooting and repair guide for CD/DVD players here which may or may not be of use to you.
    Alternately, if the time frame required to even initiate a decent repair plus possible repair/parts replacement cost, it may be more economically reasonable to consider the replacement of the unit.
What do I do with an error MP210 E 2 7
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button 4 times, the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
  • Turn off the printer.( it must be turn off) then turn it on again.
Nov 01, 2014 | Office Equipment & Supplies
The ink absorber is full
1.With the printer powered off but connected to a power source,
2.When the Power is lit, press the Stop/Reset button two times
3.When releasing the Power button and the Stop / Reset button (regardless of order),
4.When the on/off lights in green, press the Stop/Reset button the
and green, starting with orange.)note: press 4 times for waste ink counter reset. The number of the Reset button pressing LED Function Remarks
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Dec 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full
What model is it?
General reset:
How to clear E27 Waste ink absorber full
2. When the Power is lit, press the Stop/Reset button two times
3. When releasing the Power button and the Stop / Reset button (regardless of order),
4. When the on/off lights in green, press the Stop/Reset button the
Note: press 4 times for waste ink counter reset.
Dec 02, 2010 | Canon Office Equipment & Supplies
WASTE INK ABSORBER
Nov 30, 2010 | Canon PIXMA iP90 Mobile Printer
What do errors messages 5100 and 5C00 indicate when offered by my Canon Pixma iP90?
Nov 19, 2010 | Canon PIXMA iP90 Mobile Printer
Ink absorber full
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
RedhunteR
Aug 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error 5
and holding
move into a
alternately in
button pressing
Aug 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp160 is blinking orange and green 14 times ending in 1 long green.
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.(it must be turn off)
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
THE INK ABSORBER IS FULL CONTACT THE SERVICE CENTER
Jul 08, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer ink absober was full. my printer display e27 code. what can i do?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-9
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cyberhome CH-DVD 300 DVD Player Logo
66 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
