Question about Filter Queen Majestic Canister Vacuum
Oil the filter queen has essential oils rose pine eucaliptus and lemon. i have since found that you put a few drops on the filter in the blow chamber so you scent the air whilst cleaning.
    President:
  • 1,673 Answers
That does help leaving a nice fragance when you do that.
Posted on Mar 26, 2008
SOURCE:
Got a Filter Queen Majestic Limited Edition, the one with the high and low power switch, an I have to change the power cord. How can I open the main unit to reach that power cord? Thanks,
first remove the top cap under your handle.
Then, remove the three screws under the handle.
remove the rubber cover on the switch
undo the clamps on the side of the unit
lift off the chrome cover with the cord on it by the handle itself.
When you have the access there, change the filter inside the upper chamber as well.
Good luck
Nov 15, 2010 | Filter Queen Majestic Canister Vacuum
I was given a filter queen majestic limited edition but have no manual, can you help
This is a very straight forward good quality vac, with excellent filtration.
The cannister has two large clamps to release the motor from the dust chamber. Depending onb the age you may have an LED which comes on when it is time to empty the vac. The cleanest way to empty is to leave the paper cone over the dirt and carefully tip all into a garbage bag sitting on the floor.
You should replace the paper cone with a genuine fresh one each time you empty the container. In addition there is a paper disc inside the motor housing which you will access by removing the flat screw at the bottom of the plastic grille cone.
Sep 03, 2009 | Filter Queen Majestic Canister Vacuum
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
Aug 26, 2009 | Eureka Whirlwind 4480 Upright Vacuum
FQ95x...motor gets very hot very fast
It sounds like you have a blockage either in your hose or the carpet sweeper. Try dropping a coin through the hose. If it comes out then check the sweeper.
Jul 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
I'm not really a technician, but I used to sell Filter Queens and was taught how to maintain them, and have tackled "fixing" some problems. I am a 71 year old great-grandmother of 8, but have good health...
i just took my old majestic apart to fix the motor
on mine, when you open the top of the machine where the exit hook up is
you take out those three screws
the top case comes off and you can get to those three screws and alot more of the motor as well
Good Luck !
Feb 25, 2009 | Filter Queen Majestic Canister Vacuum
Oil
Guess I don't understand what you are asking, The Filter Queen vacuum doesn't use oil.
Mar 12, 2008 | Filter Queen Majestic Canister Vacuum
Need manuel
I've found an online manual in pdf format
Oct 29, 2007 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
152 people viewed this question
Top Filter Queen Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
