Question about ASUS P5RD1-VM Motherboard
Faulty time settings p5rd1 vm
Already i changed up my cmos battery (new bat) many time.everything is already set..time & date setting and saved..it goes nice if the computer is running...if you restarted it,the time stands still..(still set).but if you turn it off,the settings are already change on the date dec.11 2005 always..i found out that this date in the date on a systen info.i always need to press f1 on start to set the time and date.it tells that time & date not set.. f2 to run the default...
appreciated all your helpful advices
thanks all experts
hamlet
  • datta_j87 May 27, 2008
    I HAVING SAME PROBLEM, CAN YOU GIVE ME ANY SOLUTION?
Can you please tell me, how could i go to bios setup wizard?
Posted on May 27, 2008
    Genius:
  • 1,226 Answers
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Posted on Mar 13, 2008
2 Suggested Answers
  • 4 Answers
SOURCE: asus mother board p5rd1 vm
plz update your bios
Posted on Apr 01, 2009
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
CMOS BATTERY ERROR
You said that you already bought a new cmos bat, but still theres a problem.check the cmos battery socket,power on tyour pc and go to cmos setup,optimize default setting and set time and date.
May 27, 2008 | Computers & Internet
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
hi mayfield,
1)the problem is that cmos cell is not getting fixed or it is not touching the silverportion
2) just go to bios change date & time & save it will work
3) last option just remove all cable(hdd,cdrom,floppy,graphic card)& insert again than see it will work
4) if not than go the nearest shop & show him
Regards
shailesh
Mar 11, 2008 | ASUS P5RD1-VM Motherboard
Time settings
The Time And date Settings.
Are held Within The CMOS Battery.
This is usually on the Motherboard. ( Looks like a small round silver Coin )
They are quite easy to replace, usually about 3v-3.3volts.
Don,t change the CPU Or motherboard.
Just the Battery.
Mike @ Compurepair.
Faulty time???
Hello!
That's the first time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
may this help!
Mar 03, 2008 | ASUS P5RD1-VM Motherboard
Time setting faulty????
check timezone it's possible you are setup for the wrong one
Startup problem
you must be pressing F1 to continue after you replaced the battery, as if it boots into windows there is no problem with the bios, you may be forgetting to correct the time and date and save the settings. You need to press F2 or Del instead of F1 to get into the cmos settings
Jun 19, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
423 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
