Question about Motorola Mobility RAZR V3
Feb 18 2007
I was reading problems with the razor becuze mine has a problem where the inside screen turns whit and the outside is blue sometimes i can get the isplay to show up but its really faded and has flashing kind of lines across the internal screen the phone still makes and recives calls and keybored lights up what can i do to fix this pleases email me at sheetycobra@hotmail.com any help would be greaty appreciated
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them replaced the flexcable and LCD.
Posted on Mar 27, 2008
Low battery backup
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jun 08, 2012 | Razor MX350 DIRT ROCKET - BLUE
I have a Motorola razor phone. The phone was on and the screen was black but the buttons were still lit up blue. I turned off the phone and now the buttons are still lit up blue even when the phone is...
Hi, it is the flex of the phone that connects the screen board to the main board that make the screen display is faulty and it needs to be replaced with another flex.
After changing the flex, it will work perfectly again.
But sometimes you might still change the flex and it will still b e showing blue. In that case you will need to change the screen of the phone.
Take care.
May 21, 2010 | Cell Phones
Razor 350- Does not run
We were having the exact same problem bought this machine a year ago it ran one time and not again. it would click but nothing else would happen the battery tested god we disconnected the brakes and it works! hope this helps you!!!! yayyyyy
Mar 08, 2009 | Razor MX350 DIRT ROCKET - BLUE
Mine keeps resetting back to screen saver
mine does the same thing. you should go to different sites and read reveiws other people have the same problem. i just ignor it.
Aug 25, 2008 | Motorola Mobility RAZR V3
My Razor Front screen wont work
you will need to replace the LCD on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Motorola Razor V3 Lime Green
this is a very simple problem to fix just take it to a mobile service center and have them correct the issue for you.
Mar 06, 2008 | Motorola Mobility RAZR V3
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
White Screen on Razr, What is a "Strip Problem"
Before you open it and look inside it check to see if the magnetic switch is stuck. Check it with a kitchen magnet to the upper righthand corner of the keypad. There is a magnet in the lower righthand corner to activate it. Do some of the function work when it is closed? If they do then it is not the cable but the switch. Does the outside screen look the same as if it is closed then it is this switch? Could be a bad one, something stuck in there, or it could be stuck.
May 09, 2007 | Motorola Mobility RAZR V3
Retarded razor
I don't know why you can't answer your phone or why you banged it to get it to work but your inside screens connector may just have came loose as it sometimes happens with out you doing anything wrong. Just take it apart and check the wires on the solved problems I think there one that tells you how to do this.
Mar 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
