Question about Vivitar ViviCam 35 Digital Camera
Pilar Its impossible to find the new hardware ???
    Problem Solver:
  • 14 Answers
I would never use my camera to transfer pix to computer. I would buy a (usb or other) card reader and save wear and tear on camera. Otherwise I need more info.
~YCSPhoto~
Posted on May 11, 2008
Where are the drain holes in the sunroof gutter? Do I have to remove hardware to get to them?
Now i have no idea on this model but a lot of vehicles have tubes under the headlining that do to either the back or the sides and run down the door pilar or the rear if a hatchbackor the quarter panels if it has a boot or trunk
Apr 21, 2015 | BMW X5 Series Cars & Trucks
Recommend tire pressure in nexen 225 / 45 / 18
not knowing year make model and motor size it next to impossible, what you can do is open drivers door and look on edge of door or pilar where door latches and you will find tire inflation pressure. if that is the recommended tire for car or call your local firestone or goodyear tire dealer.
Sep 11, 2014 | Cars & Trucks
All motherbord audio driver
When you connect something to mother board for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. It is not the motherboard, but the operating system that needs the driver(s) From Windows 7 and up, for most hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old HV. They only spend time and money to get their new hardware certified on the new operating systems.
And be aware, it is virtually impossible to install older operating systems, on new motherboards, because the old operating systems don't have drivers for the modern hardware.
Jul 05, 2014 | Intel Computers & Internet
How do you adjust the brackets to open wider on a unisport car roof rack
Im not positive with those but usually they have a hex screw on the pilars that you loosen, then slide the pilar forward/back on both sides, then re-tighten. Newer racks have easy position turn style knobs but older ones have a screw or bolt and may have a plastic cover that you have to pop out with a flar head.
Jun 22, 2014 | 2004 Honda CR-V
DCG-20
There are two hidden screws on the botton in two small pilars. Use a drill in order to open the pilars and you will find out the philips screws.
Feb 21, 2014 | Cuisinart DCG-20N Electric Blades Grinder
My Malibu has a leak somewhere the floorboard in back of drivers side is soaked, I read it could be the drain from the sunroof or ac plug how can I find out where it is coming from?
some black ink dissolved in a bucket of water ,i would plump for the sunroof they empty down the centre door pilar i think ,only ever seen one of these cars though here in spain so i couldnt really say but a lot of europeon cars run down the centre door pilar
Dec 29, 2010 | 2004 Chevrolet Malibu
We just installed the new delta pilar touch in our new home last week and the red light is already on and no water, does that mean the batteries are done already? And will the water not work manually even...
Levina, I recommend you call Delta's Customer Service Department and explain about the red light. If the batteries were new when they were installed, they should still be good. I had a problem with our Delta Pilar and when I called, the customer service representative was very helpful and solved the problem while we were talking. Good luck and please post back to let us know what happened.
Carly
May 20, 2010 | Delta Plumbing
What are the panels caled at side of windscreen
A pilar panels
B pilar panels are between front doors and rear side windows
Apr 11, 2010 | 2005 Mini Cooper
'06 Volvo V50 drivers seat belt is jammed, there is no play in the belt and the ratchet locks immediatly no matter how gently it's pulled. Same problem with passenger side the day before but it righted...
I solved this on my 95 volvo 850 glt as follows:
pull the seatbelt pilar cover off from the door jamb. this runs vertically up the pilar between the front an back door (beside the front seats. Once opened loosen the belt by gently pulling the belt upward toward the roof. You'll have to do this sometimes in small increments. Once the seatbelt is pulled out all the way, spray small amount of lubricant into the joint where at the top of the belt spool. Also use a screw driver to push spool upward while pulling the belt. At first it's only going to release a little but eventually the lubricant will work its way into the seam at the top of the belt spool and loosen up the stuck inertia catch. Until it completely loosens you might have to remove the pilar cover again and work the seatbelt out (also use the screw driver technique described above) in order to use the seatbelt. When parking, I would relatch the seatbelt and pull the slack up around the back of the head rest. After a day or so it worked normally.
good luck and don't give up.
Feb 07, 2010 | 2008 Volvo V50
Driver seat belt will not extend out from door pillar.
Nov 05, 2009 | 2000 Volvo S80
Vivitar ViviCam 35 Digital Camera Logo
18 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
