Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
I have the exact same problem with mine. It definately isn't a feed problem. Even though mine has had very little use as well I'm replacing the driver on mine. I'm sure the previous person was describing the same issue as mine will almost drive the entire brad except for about 1/8" and it bends it causing a jam.
The only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
