Question about Zanussi 24 in. DE6850 Free-standing Dishwasher
How to replace heating elemant on Zanussi DE6850 Dishwasher
My dishwasher will only do a full cycle on the ronse hold. All other cycles do not progress as there is no hot water. Is it easy to replace the heating element and if so how?
Thanks
  • 2 more comments
  • cooranig May 17, 2008
    I have exactly the same problem - on all other cycles there is no water then the drying light starts flashing along with the program light
  • IEDAMC1 Jul 30, 2008
    WATER IS NOT HEATING
  • tom_a_oneill Jan 02, 2009
    how do i replace the heating element
  • Janusz Beuckner Jun 19, 2013
    replace the heating element and reconfigure your hardware parameter to temperature max.
  • 185 Answers
Is your water heater set on 120 degres
Posted on Mar 31, 2008
SOURCE:
Where is the heating element on a zanussi de6850 dishwasher
remove RHS panel and you will see it bottom right. looks like a round cylinder with wires going into it.
if not heating worth looking at main board as wel for a broken solder joint on heater relay. bit of solder will sort this
Oct 19, 2010 | Zanussi 24 in. DE6850 Free-standing...
DE 6850 not drying
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
Zanussi de6850 not heating up
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Dishwashers
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
ZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR DRYING
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel P31bf5e2.jpg
Apr 12, 2009 | Zanussi 24 in. DE6850 Free-standing...
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi de6855
most probably the pcb unit...had a few of these changed pcb and cured fault, not a job for a novice to be honest, think the parts is about £70-80 from memory.. ally
Jun 30, 2007 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher was tipped and won't run
I have the same problem if you take off the tray below the front door and set a small blow heater in there it will dry the out the anti flood switch. It usally takes about 25 mins for the machine to start working again.
Feb 21, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi 24 in. DE6850 Free-standing Dishwasher Logo
1,667 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
