Question about Metrologic Instruments 9520 Voyager
Can't even start Metrologic voyager 9520
I new to this. I bought scanner(model named in subject).
In box,there was only scanner with rs232 connection
+ handler + AC adaptor.
1st I don't know where to connect adaptor on scanner,there isn't ani adaptor connection on scanner.
2nd I just connected rs232 to my PC ,but it acts like it is "dead" - no signs.
I tried with driver and other software for scanner from Metrologic website but it is even too complicated.
Starter help please!
  • 1 more comment
  • Anonymous Apr 05, 2008
    hell yeah I have the same problem , let me know if you get any response...
    [email protected]
  • Anonymous Jul 18, 2008
    HOW TO GET STARTED
  • Anonymous Jan 19, 2009
    part number 53000c-3 is RS232 cable? I'am I right?
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Posted on Nov 25, 2008
Anyone???
Posted on May 07, 2008
SOURCE:
What is the proper cable for my MS9540 scanner?
Now Metrologic is under Honeywell AIDC
Voyager 9520 9540 Laser Scanner Hand Held Honeywell
If not mistaken,the USB cable P/N should be MX009-2MA7S
Jul 24, 2014 | Metrologic Instruments MS9540 Voyager...
I have a casio se 300 and a voyager 9520/40 scanner....how do they connect?
No. you have the wrong scanner interface. The initial setup for scanners can be tricky also. It is supposed to be set by the dealer with special service bar codes to sync the scanner with register. If you bought it from a dealer or re-seller, you should see if they have an RS232 scanner and casio settings. They are not plug and go.
Dec 20, 2011 | Computers & Internet
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
Drivers for metrologic ms9500 vpyager
All the serial drivers and utilities are available for download from Honeywell.com the company that owns the line. Assuming you Voyager is either the 9520/9540 model follow the link below and you will have access to all the relevant software for your device.
Hope this helps FixYa,
Chris
Jun 22, 2009 | Metrologic Instruments 9520 Voyager
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
1,139 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
WatsHVAC
Level 1 Expert
George Etukudo
George Etukudo
Jason E
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
