Question about Pioneer DEH-P6800MP CD Player
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
1964 impala, has yellow, green. black, blue, light blue, white, purple, and gray wires, i need to know what these are for hooking up a wiring harness for a 2000 pioneer car stereo. i need to know on my impala, which colored wires are the power, accessory and ground( i suppose though i just hook up the black wire from the pionner harness to a ***** for ground, or part of the chasis, help!).
There is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 138 Answers
You'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Posted on May 09, 2008
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Pioneer DEH-P6800MP CD Player Logo
450 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
