Question about Microsoft Office Outlook 2003 for PC
IE 7.0 Change it into High Encryption.
Hi, I am using IE 7.0 with Cipher Strength of 256-bit on Windows Vista. How can I change it to 128-bit? I can not find any HIgh Encryption Pack online for this version. Please help me.
  • ivyzhou312 Mar 17, 2008
    Thank you, but sry I still don't know what to do next in admin tools.
    Problem Solver:
  • 10 Answers
U can change the cipher strength by edit the properites of the IE7.0
or change in "services" which is in control panel -> Administrative Tools
Posted on Mar 15, 2008
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
HOW TO CHANGE SSID
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
Nov 08, 2010 | 2wire (1000-000057-000) Modem
How do I install my WEP number
go to 192.168.1.1 If you have already configured the router for internet access, then just click on "configuration" otherwise, go through the steps to configure it according to your ISP's instructions, then click on configuration. then wireless. Then go down to privacy settings.
Pick which authentication type to use ( I recomened open)
Then pick the highest encyption meathod that all of your wireless devices are capable of. 64-bit, 128-bit or 256-bit.
Most devices use 64 and 128 bit, but if all of your devices use 256, then use it. Then create a wireless key to use.
If key select is selected, the WEP Key is treated as a string of text characters, and the number of characters must be either 5 (for 64-bit encryption) or 13 (for 128-bit encryption) or 29 (for 256-bit encryption).
If not selected, the WEP key is treated as a string of hexadecimal characters, and the number of characters must be either 10 (for 64-bit encryption), 26 (for 128-bit encryption), or 58 (for 256-bit encryption). The only allowable hexadecimal characters are 0-9 and A-F. (My hint is to use hexadecimal, it is eaiser)
If you would like to create a new WEP key go to this site (http://www.powerdog.com/wepkey.cgi) and type in a passphrase and click generate. it will generate 4 64-bit keys and 1 128-bit key.
choose the best bit 64 or 128 bit, then copy and paste it into the correct key box(es)
Oct 12, 2010 | Westell Wirespeed VersaLink...
I downloaded Windows 7 and my wireless laptop won't connect to my 2wire. Where can I get new security key code or info get my laptop to work?
Hey pkkern,
Your default 10 digit security is located on the bottom of your router.
If you want to change it or for some reason your default key is no longer working we will have to get into the routers configuration homepage.
To access this open up your Internet browser and write in this address, (which is your routers address) 192.168.1.254.
If your routers homepage does NOT open up check to make sure you have no software firewalls
You will see a wireless network security section, use the following information to select a custom wep-key.
Change your wireless settings and use the following information if you want to change to a custom WEP key. 64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
Thanks for using fixya!
If you need information just comment in this thread and I will get back to you, don't forget to leave feedback!
Cheers,
Jul 24, 2010 | 2wire (1000-400108-001) Router
How to join Vista computer to Windows 7 homegroup computer. They ping each other but they are not accesable.
If other users are unable to access your network shares, especially if they are using older versions of Windows or old 802.11b wireless adapters, their systems might not support 128-bit encryption. Select Enable File Sharing for Devices that Use 40 or 56-bit encryption.
To simplify sharing, you can disable password protected file sharing. To do so, select Turn Off Password Protected Sharing.
Oct 06, 2009 | Microsoft Windows Vista Ultimate Edition
My PC won't connect to my apple airport. My roommates macs do. On the PC it shows full signal strength, but won't connect.
Be careful of the password, change it to one with 13 charactors, less than this the computer auto fills to make up and macs use a different default character to some others
Jun 13, 2009 | Apple AirPort Extreme Router
System Information
Physical memory is ur addon hardware memmory available memmory means  256 - currently usage virtual memmory = free space in ur c drive page file space is related to virtual memmory cipher strength is encryption level of your internet explorer
Nov 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Hi All , Pls do help me in , where I am not able to vist any secured website on vista Thanks & Regards sai
could you please expand a little, you want to purchase vista on a secure web site?, or you wish to know about Vista, or are you not able to view secure web sites using Vista. If it's the last then open up internet explorer IE7 , select tools on the menu bar, then internet options at the bottom of the list, then click content then select the enable button, you may be asked to make up a password, then when you get all the slider options, move then further along to the right to allow more content to be viewed. Then go to the privacy tab and make sure medium is showing if not click settings and alter.
Aug 22, 2007 | Microsoft Windows XP Professional With...
Microsoft Office Outlook 2003 for PC Logo
354 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
