MP3 player problem
I just bought an Audiosonic KMMP1GBPR 1GB MP3 FM Player. The instructions tell me to push the "mode" button to access the menu but I cant see a "mode" button. When I turn it on, no text comes up, the backlight lights up and when I toggle left and right with the wheel it just changes the color of the backlight. I have a feeling it may be faulty. Where is the "mode" button and how do I use it? Cheers
First turn it on and make sure it is not locked
the lock button is the slider one
2. use the wheel from side to side to get to music
3. tap wheel to find the song you want and tap the on off button quickly to play.
I hope this helps, it worked for me
Celeste W
Posted on Dec 25, 2008
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Might it be on 'lock'
Posted on Jun 13, 2008
You push the left right wheel down
Posted on Mar 20, 2008
Heh, I got exactly the same thing. Mine is saying the player is "almost full" - it has the two songs it came with - and they work - but it wont let me copy anything from the computer. The computer knows the mp3 player is there, i used the disc that comes with it, and it still wont do anything
Posted on Mar 15, 2008
Cannot get my irulu mp3 player to work
The button at the top of the mp3 player The Mode button. If you move it side to side it moves your selection. Once you are in the mode you want.. Say music you push in on the mode button. To turn in off and on you hold the Play button... It took me awhile to figure out the pushing in of the mode button since I lost my guide.
Mar 05, 2012 | IBM ThinkPad Audio Players & Recorders
Fm-Radio problem
that model does not support radio.
Jun 21, 2009 | Audio Players & Recorders
Bought Sansa 2GB mp3 player and can't work radio
Dude I have one in front of me so listen and follow along first turn the unit on, second push the menu button, this is the very small buttonright to the right of the SANSA namewhen you push that button the first thing you will see is the words MUSIC while thats on the screen hit the play button that looks like this >|| and you will scroll through all the settings you will see the fm radio selection when you get to it hit the middle button and the radio will come on.
Mar 21, 2009 | SanDisk Sansa Clip MP3 Player
The sansa clip mp3 player has totally frozen up-stuck on fm radio
Press the Home button and see if it will go to the settings menu. If it will, change the USB Mode to Auto. If it won't, hold in the power on/off button for 15 seconds to reset the player, and try again.
-Tha Mp3 Doctor
Feb 11, 2009 | SanDisk Sansa Clip MP3 Player
I FOLLOWED THE CUSTOMER MANUAL BUT CAN NOT FIND THE FM MODE
i think i have a solution. if it is pretty easy to press that button you are talking about than the button might be jammed.
Jan 04, 2009 | Nextar MA933A MP3 Player
Fm radio and recorder modes
On this model, the Power button and the Menu buton are the same key - press the Menu button to go to the main menu, and it will display FM and Voice options.
Here is a link to the user manual:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa c200 MP3 Player
Problem in reading files
i have problem with my T.sonic 610 1GB Mp3 player. after storing the files the player is not able to read the files. it simply shows ***no files***. the fm player is working normally. even after pressin the reset there is no use.I Press power on button again & again ON/OFF please tell me how to deal with this.
Ashish
Nov 06, 2008 | Transcend T-Sonic 840 MP3 Player
Fm 6709
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 12, 2008 | SanDisk Sansa SDAMX-FCT (619659024598) FM...
Craig mp3 1gb player cmp580d
this is a no brainer.....first thing I did was set up (formatted) the player with the disk drive utility supplied with mp3 player. Next you add in your MP3 songs. Turn on your player and with the mode button...go to MSC it will be highlighted black....then press in mode button to enter folder. Songs shouls be seen....and press power button to start.
May 15, 2008 | Audio Players & Recorders
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
187 people viewed this question
 Grubhead
Grubhead
