I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
  • 1 more comment
  • lowilli Mar 13, 2008
    No help at all. That had already all been done before I asked about playing a disc on my DVD.
    Everything is connected okay. I followed the directions (I thought) on how to play a movie on my TV screen through my DVD which is connected to the TV. I know the DVD is working, but I can get no picture, and wonder if I pushed the wrong buttons in the wrong order somehow. It has been a year since I have used it, and I have forgotten how I did it before.
    I wish I could understand what you are asking? It doesn't make much sense to me. In what player? I have a new Sony Bravia HD TV, and the Zenith DVD player is hooked up to the TV (professionally), and I know I am supposed to enter something into the TV to get it to play my movies, but I have forgotten how to do this. I try and try, but have lost my instructions on the Sony. I go to V1, and put my movie in, but no picture, so I have forgotten something here.
    Master:
  • 377 Answers
Hi!
I would like to know the model of your player & also the TV..
One more.. have you try inserting another disc?
Thanks,
Posted on Mar 13, 2008
  • 407 Answers
Hi 1st you chack your dvd disc any pc .......to test your disc if your
disc ok ....then setup your dvd player backside output conection properly....
  1. chack cable conection
  2. setup video out put yellow pin
  3. conect tv input video pin...
  4. then remote av to chack tv screen
  5. hope your picture & audio both ok
Best of luck......
  • krishna Singh
    krishna Singh Mar 13, 2008
    hope everything ok to setup properly..............
  • 790 Answers
Hello sir in which player are u trying to play it ??? Whats the video format ???
SOURCE:
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
Sep 22, 2009 | Coby TF-DVD7005 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
No picture
I gave up on the cheap Coby unit and upgraded to a more expensive toshiba one.
Sep 07, 2008 | Coby DVD-224 DVD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Wrong Disc
It is a bad data cable from the dvd head to the main board
Feb 14, 2008 | Coby TF-DVD7005 Portable DVD Player
Since the device is new, I suggest that you take it back to the shop, ask for a replacement and check it while in the shop to make sure its working. This is assuming that you made sure that you're trying to play the correct format discs. Consult the manual on which format DVD's it can support. Its multi-region so that can't be the problem, but its possible that you're trying to play other unsupported formats. Try also playing other discs - audio discs, DVDs, DIVX etc... make sure the disc isn't scratched badly. But the bottom line is you shouldnt have problems on the first day, take it back. Good luck!
Jan 25, 2006 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Ekse
