Question about Apple iPhone Smartphone
Touch Screen Not Working On Iphone
For no reason at all my screen is not responding to my touch. I reset it by holding top and home button and it still does not work. I can't unlock it, turn it off, or answer a call. The phone is unlocked. Please help me!
  • squeeze23 Jun 04, 2008
    touch not working
  • dubai-omar Jun 04, 2008
    i cant use the other half of the touch screen
Dear fellow,
I am trying to discharge my battery but still its showing some percent of battery remaining. Can't I discharge 100% it to percent.
Please suggest. My iPhone still in same condition (Touch not working on half of the screen).
Thanks in advance.
Posted on Apr 15, 2008
The only solution is let the battery ran out (i believe about 9 hours) and then you'll be fine after that. I guess the problem came from connection between the LCD and the C.Board (HW). Good luck. Restore may help but it'll happen again when you turn the phone off then turn on again(it'll freeze up again)
Posted on Mar 16, 2008
SOURCE:
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
Ipod is disabled
The 8GB iPod Touch music player is equipped with the iPhone iOS operating system software. The software enables the music player to be configured in a variety of ways. Applications can be installed and run within the Apple iOS software. In some situations, an application may cause the Apple iPod to stop responding, preventing it from being shut down. In this situation, the unit must be manually reset.
Press and hold the "Sleep/Wake" button located on the right side of the top edge of the device. Press and hold the "Home" button located under the display screen. Hold both buttons for least 10 seconds. Release them when the Apple logo appears on the screen, indicating the iPod Touch has reset.
Feb 02, 2013 | Apple iPod touch
Hi my apple iphone touch screen freeze and couldnt respond when you touch it.what is the problem. and Mode 3GS+. GSM Quad-band cell phone.uses two sim card
Sometimes the phone just gets stuck and needs to be reset. Hold Power (Top button) and home button (low center square button) together for 7-10 seconds and let go when the apple logo appears.
Feb 13, 2011 | Apple iPhone Smartphone
Hi there my daugters ipod touch 8gb screen gone white and does not respond when you press the screen
You may need to reset. Important: Only reset your iPhone or iPod touch if it is no longer responding. To reset, press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Jul 19, 2010 | Apple iPod touch
Iphone touch screen is not working. Restored the phone from backup succesfully, but screen still doesn't work. Phone receives calls, etc., but can't unlock or answer calls because screen doesn't respond to...
Even though the iPhonemag-glass_10x10.gif is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
  1. tep 1 Remove the wiping cloth that came in the small black envelope along with the iPhone. Wipe the smudges or dust off the screen with this cloth. It is best to wipe in a circular motion.
  2. Step 2 Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating systemmag-glass_10x10.gif.
  3. Step 3 Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
  4. Step 4 If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
  5. Step 5 Press and hold the home button as well as the reset button on the top of the phone to turn the iPhone off. A red slider will appear. Slide it to the right to turn the phone off. Press again on the "Reset" button on the top to turn the phone back on.
  6. Step 6 Completely reset the iPhone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets and the Apple logo appears on the phone.
    • If you are using the iPhone in cold weather and wearing gloves, the iPhone will not react to the gloves as it will to the touch of a finger.
    • If the touchscreen is dirty, do not run the iPhone under water. Doing this will likely ruin the phone, but even if it doesn't, it will possibly make the phone run slower.
Nov 15, 2009 | Apple iPhone Smartphone
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Right side of i touch screen non-reactive
Perform the under given steps to troubleshoot the issue:
(i) Clean the iPhone screen with the cleaning cloth that came in the box with the iPhone.
(ii) If you have a protective plastic sheet or film on the touchscreen, try removing it because it may be preventing the touchscreen from working properly.
(iii) The current application may not be responding (frozen), press and hold the Home button below the screen for at least 30 seconds, until the application you were using quits.
(iv) If that doesn't work, turn the iPhone off and turn it on again. Press and hold the Sleep/Wake button on the top of the iPhone for 30 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
(v) If the iPhone did not turn off, reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for a least 30 seconds, until the Apple logo appears.
If the issue persists then service will be required.
Sep 08, 2009 | Apple iPod touch
IPhone touch screen freezes and stopped working
hold down the home and power button together, should reset the iPhone and stop this happening. (you will not lose any data)
Aug 04, 2009 | Apple iPhone Smartphone
The iphone 8GB Non 3G Touch screen will not work after the phone
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Dec 18, 2008 | Apple iPhone Smartphone
Iphone touch screen are not responding when i touch them
hold down the middle home buttton and the black top button to reset it
May 29, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
319 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
