Question about Refrigerators
Not cooling properly
Fan in freezer not blowing last 48hrs
  • 1 more comment
  • rayrayray Apr 30, 2008
    Not cooling-compressor is operating & fan down below.Two fans inside mot operating.What is the troubleshooting procedure. Thanks Ray
  • Anonymous Jan 16, 2009
    I have refrigrater of BPL make performing well scince last 8 years. But recently it stop. I change thermostate , wchich is not functioning properly.
  • Anonymous Apr 23, 2009
    i have a refrigerator of bpl is working weel, but last 2 month fan in de-fridge is failing, that i had replace four time , still i is not working properly
    President:
  • Refrigerators Master
  • 2,651 Answers
Is ther e frost on the evaporator directly below the fan??? if so the fan should be spinning. try taking off te power leads to the fan and check for 110v. ifyou have 110v between the 2 fan leads and its notspinning you have a bad fan
Posted on Mar 13, 2008
We have a 2 door LG refreidgerator.(2 years) We can see the freezer is cooling but nor cool air coming into the refridgerator compartment what would be the problem.
Hi!!
Check your temp. settings, Sometimes we move the controls by accident. Also check the fan in the freezer, make sure it is woriking properly, this fan is the one that blows cool air into fridge compartment.
Good Luck!!
Mar 13, 2010 | Frigidaire FRT21S6A Top Freezer...
The freezer works great, but the refrigerator isn't cooling properly as of yesterday
Check the vents coming into the frig from the freezer and with the fan in the freezer blowing feel if there is any air blowing into the frig., if not then check for ice buildup in the freezer. sometimes the ice will block the fan and or vents. Defrost if there is frost and ice buildup.
Mar 09, 2010 | Whirlpool Refrigerators
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Side by side fan in back doesn't
A temporary solution for this, is to use a fan to blow some air to the back of the unit. Looks like -as you already figured- the condenser fan is broken. If your fridge starts cooling with the external fan, you may have keep it working on this way until it is fixed.
If you had previous service in your appliance, perhaps the tech guy forgot to plug the fan connecto to the power.
Aug 30, 2009 | Hotpoint Refrigerators
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
301 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
