USB Flash Drive Problem
When i plug in my usb and try to acces it it comes up please insert a disk into disk g. Then sometimes the files on my usb may come up but then i try to access them i cant. I keep getting the same message. Also my usb does not glow like it used to. There are important school files on my usb. If it is broken can u recommend a way to salvage these files. Please help.
  • phill15 Mar 13, 2008
    yeah tryed that mate it still says the same thing. Please insert disk into removable disk g.
    yeh guys i've tryed to copy the files. Even trying to make a backup . It says that it cannot access this disk. Should i try a computer repair place or digital camera place. Cause i really need the files.
  • 35 Answers
Well, your usb flash drive may come to its end of life.. well, if theres a chance that you can access your files, better make a copy out of it, for your back up. and if you could make a back up copy of your usb flash drive, try to format your flash drive and observe if the same problem will come out, if so, well your usb flash drive may be already damage.
Posted on Mar 13, 2008
  • renato ferraren Mar 13, 2008
    well in your case, you should go to a computer repair shop, because it is a usb flash drive, its considered as a computer accessory. well digital camera shops only repairs camera and other media cards which cameras used.
Instead of trying to access them when they do come up, try shifting them or making a backup.
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
My flash drive is inserted in a USB port. It says
Try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 13, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 22, 2009 | Transcend (589307) Media
I inserted my Apcer USB 1gb flash drive, it was recognized but when i open it, it says ''Please insert a disk into drive X:''
Is there anything on the disk it self? If there is/was a virus on the disk, it could have left a 'autorun.inf' file on it ... So try Right-click and select explore. Or try to access it via the Total Commander
If that doesn't work, try formatting the disk.
This is an often problem with most low-end flash disks.
Did you receive some software with that disk?
Mar 18, 2009 | Electronics - Others
PQI 1GB Intelligent Stick USB 2.0 Flash Drive
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
Dec 03, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
When I plug it to my PC,It says "please insert a disk into drive".And I can't format it. T with Tanks
Jul 11, 2008 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Computer keeps on telling me "please insert a disk into drive E:"
try to rerfresh on MY COMPUTER then it will appear on E, if it won't open, right click then Explore.
May 07, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
