There is a small silver-coloured battery, about the size of a $0.25 coin, on the motherboard.
It needs to be replaced, because it has become weak.
Turn your computer off, and disconnect the AC power cable.
Locate the battery, and note the printing on the battery -- the replacement battery must be mounted in the same orientation.
Gently, "lever" the battery out of its socket.
Buy a replacement, and push it into the socket.
Reconnect the power.
Turn the computer on, and set the time.
Testimonial: "i think it will work i will try thanks"
SOURCE: when i switch the ups power on my pc automatically starts and....
Sounds like you CMOS battery is FLAT, please locate and replace, it is a 3.6V flat "Cell" This may just sort you out. Checksum error is because, something is different from the stored checksum it has in memory.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
hope this helps you
