Question about Vacuums
Replacing and connecting
I need help on replacing a motor to my sanitaire vacumm sc887-b
    President:
  • 1,673 Answers
From the bottom, remove the the fan cover and fan. Then remove the top cover, it is held on by 2 springs that you remove from the bottom, and then the screw in the HT. adjustment knob. Take out the four screws holding the motor, then the motor will come out. Part # for a motor is 54352-11, or you can rebuilt your old one. Go to a repair shop and they can order what you need.
Posted on Mar 13, 2008
Sanitaire canister vac 1000 watts
The obvious answer is to reinstall or replace.
May 04, 2014 | Eureka Sanitaire S3686 Bagged Canister...
I have a Sanitaire model S663. It came with the 12" Vibragroom I aluminum roller brush E-53272. Is the Sanitaire Vibragroom II 12" steel roller brush E-53270 interchangeable?
If you go to this URL:
http://evacuumstore.com/c-57-sanitaire-parts.aspx
You will see both of the brush you mention. Compare what they show and if necessary, call the on line store for their input.
Oct 03, 2010 | Eureka Sanitaire S663 Upright Vacuum
The motor is sounding real loud lately like its straining to operate, any ideas?
It could be a worn belt. Sometimes worn belts can cause the vacuum to make funny noises. I have listed a link to the owners manual and a link to the belt you need.
Eureka SC4580 Owner's Guide
Eureka SC4580 Replacement Belts
Nov 03, 2009 | Eureka Sanitaire Commercial SC4580 Upright...
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hello, I have a Eureka Sanitaire upright vacuum. It is not picking up as well it usual and I notice it no longer has that deep motor sound. What do you suggest?
Does there seem to be good air-flow and suction? If not, look for a blockage somewhere. Otherwise (and more likely because of what you say about the sound), look to the brush roller. Does it rotate when the machine's switched on? If so, maybe the bristles are worn and no longer make contact with the carpet properly. If not, the belt that drives the brush roller is broken and must be replaced. Your Owner Manual will tell you how to do this.  Good luck!
Jul 17, 2009 | Eureka Sanitaire Commercial SC785 Bagged...
Sanitaire vacuum cleaner sc684
supposed to be a foot pedal on the left rear of the motor housing
Aug 24, 2008 | Eureka Sanitaire SC4570 Bagged Upright...
I need to connect my new motor to my sanitaire vacuum sc887-b
One side of the cord goes to the motor, the other motor wire will go to the switch.
Mar 13, 2008 | Vacuums
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
