Question about Sansui DTV3200 32" TV
Picture problem My Sansui television picture has taken on an hourglass type of display. How can i adjust this? I've gone into the menu with the remote, but I only see settings for color/tint/etc. There seems to be nowhere to adjust the actual picture display. Any ideas? Thanks a lot!
  • 934 Answers
It's not an adjustable problem and not all that easy to guess at either. Power supply is a usual suspect and my best suggestion would be to take it to a reliable shop for an estimate.
Bill
Posted on Mar 13, 2008
SOURCE:
Sansui lcdtvs2220ym-'s service menu code
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 07, 2016 | Sansui Televison & Video
SANSUI SERVICE MENU model SAx40ff-zm
Sep 11, 2016 | Sansui Televison & Video
SAX40FF-ZM LCDTV SANSUI SERVICE MENU
Tell me sansui service menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 26, 2015 | Sansui Televison & Video
Desktop off of the screen
That might be the possible resolution the TV can recevie. Nothing more can be done.
May 20, 2013 | Sansui 19 in. LCD TV
Uneven backlight
Your set is probable defective
Sep 21, 2017 | Sansui Televison & Video
The color on my 32 inch sansui flat screen is xray like dark.
Hello
Either your Sansui TVs screen voltage has gone very low, or its brightness control section inside its chroma IC has damaged. To make sure which is faulty, you have to open your tv. There is an LOT [Line Output Transformer], which can be locted on the main board of your TV, from which three wires will go to the picture tube, out of which one will be connected directly to the picture tubes upper side, look like as it is sucked by a rubber ******. Usually this component is balck in colour and will have two adjustment controls integrated with it, marked as "screen and focus". After switch on your TV, just adjust the "Screen" control preset a little clockwise to see whether there is any advance in the bright ness of the picture. If the focus voltage is less or its wire connection to the picture tube base socket gets corroid; this type of fault may occur also. Check that also. If these does not help you, the chroma IC has damaged, and should be replaced with same type and number. OK.
Feb 24, 2011 | Sansui 32" TV
Sansui 1908 sound but no picture, kid was using
Return the thing. Ur LCD inverter board is dead.Or call for warrenty repair.The LCD inverter have no set of times,it dies anytime.Must replaced the LCD inverter board to get picture back.
Nov 06, 2009 | Sansui 19 in. LCD TV
Hourglass Picture
can you please identify the unit model/maker
Jul 08, 2008 | Primax Electronics HT2778P TV
Too much yellow in picture
The problem with the set is that the blue gun has gone weak, and not emitting at par with red and green guns in your picture tube. Turn of the blue screen and get the grainy display on the screen (detach the cable) and enter into service mode to fine tune until you get a perfect or black and white grain pattern.
Dec 19, 2007 | JVC AV-27230 27" TV
Sansui DTV3200 32" TV Logo
164 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
