Question about Dell Microsoft Windows XP Home Edition
Wireless Keyboard I need help on how to troubleshoot my wireless keyboard because it is not responding to any keystrokes at all. The mouse, which is also wireless, is working. Only these two pieces of hardware are wireless.
  • Lynu Mar 18, 2008
    Many thanks for your assistance. I bought new heavy duty alkaline batteries and installed them into the cordless keyboard. And followed your instructions. However, it still did not fix the problem.
    Lynu
    Scholar:
  • 76 Answers
First put in NEW Lithium or at least alkaline batteries, next disconnect BOTH USB wireless devices, then reconnect them and insure the devices are in sync with their USB sending unit. A re-boot may also be necessary.
Posted on Mar 13, 2008
SOURCE:
My sister has changed the batteries in he wireless
batteries fresh? properly inserted? try reloading the software ... use a standard keyboard to get stuff going again.
May 05, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My logitect wireless keyboard will not work.
HI,
Please reinstall the drivers of your keyboard.This should fix the problem.
Sep 17, 2008 | Logitech LX 710 Keyboard/Mouse
Tip
Wireless keyboard and mouse
Most problem with the wireless keyboards and mice are one of them is not responding or not connecting to the wireless USB adapter that's connected to the computer, here are the things that you may do:
1. Make sure to use fresh batteries.
2. Verify if the keyboard and mouse are turned ON.
3. Avoid putting any possible wireless interference such as base of a cordless telephone and cell phones.
4. In pairing up the keyboard or the mouse, try pressing the connect button on the USB wireless receiver followed by the connect button on the wireless keyboard or mouse.
5. If that did not help, then hold down both connect buttons (on the wireless receiver and on the keyboard or mouse at the same time for five (5) seconds and then release them both).
The keyboard or the mouse should connect to the USB receiver. If same problem occur, then the device needs repair.
on Dec 01, 2009 | Computers & Internet
My Dell wireless keyboard has stopped working. The optical mouse is still working, but the keystrokes are not being transmitted from the keyboard. I have already replaced the batteries and checked the...
Underneath the keyboard is a little 're-set' button. When you push this it re-synchs with the wireless antenna. Make sure you hold it down long enough fo rthe keyboard to synch, usually about 5 - 7 seconds.
Dec 19, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard isn't responding but mouse is
open the Logitech utility and try to reconnect the keyboard and pair it with the mouse. if it doesnt work uninstall/reinstall the software for your wireless mouse/keyboard.
May 27, 2009 | Logitech Wireless Access Duo Optical...
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Wirelesskeyboard and mouse
Hi folks,
Well first make sure the batteries in the wireless keyboard have enough power.
Also, because it is a wireless keyboard, there is possibly an issue with latency, ie how much time it takes for a packet of data (a series of keystrokes) to get from one designated point to another.
The wireless medium itself introduces some delay. The size of the packet introduces delay in a round trip since a larger packet will take longer to receive and return than a short one.
My point is there is already the wireless medium to consider. If you then couple that with the settings to which the keyboard is configured (In keyboard, in Control Panel, or maybe the software that was installed from the disk that came with the mouse/keyboard), eg Keystroke repeat rate, keystroke repeat delay etc. then the process has a capacity to falter.
I would put the Repeat Delay for the keyboard at about 2/3's and experiment with the Repeat Rate in case that makes a difference.
As for setting it as the 'default' keyboard, I'm not exactly sure about whether that would make a difference, and I also don't know if it is possible to set it that the laptop 'completely ignores' the original keyboard, as I'm sure the CMOS needs to detect a keyboard on bootup, in order to proceed. USB/wireless keyboards, I imagine, are 'loaded' after this point, so if you actually 'disabled' the original keyboard (in order to stop it possibly causing error), there is a chance that the laptop would not boot in the first place. This is just a theory of mine, however..
I would play with the sensitivity (keyboard repeat rate and delay) and make sure your batteries are juiced up.
I guess you could scan, fix and immunize with Spybot, just in case there is a malware issue there too.. Just a remote possibility..
I actually have a wireless Belkin keyboard and mouse somewhere, I'll look them out and check the software configs, and see if I can give you any more ideas. The software that came with the keyboard and mouse would be the place to start, to make them 'sort of default', in the sense that system resources would be more prioritised in their favour. Have a look in that software, and I will do the same and post here if I come across anything.
Hope this helps
Chris (ziraffa)
ps sorry about the technobabble ;D
Jan 11, 2009 | HP Pavilion dv9000z Notebook
Dell Wireless Keyboard stopped responding, please help.
The keyboard should have a button underneath it. Press the button on the usb controller first and then the button on the keyboard. Repeat a few times to see if it connects. If you are still having trouble try another set of batteries as some batteries are not designed for wireless products.
Aug 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless Keyboard from Belkin
the reciever unit is powered when you plug in to the computer but the mouse and keyboard use AA bateries. Maybe you put in dead batteries? hope that helps.
Aug 03, 2008 | Belkin Wireless Keyboard/Optical Mouse...
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
113 people viewed this question
Ekse
Clive
Clive
