Question about Refrigerators
Freezer/fridge fan not turning
Possibly stuck in defrost.cooling,but not sufficiently
  • bmhaji Feb 28, 2009
    The fan at the back of the refrigrator is broken I want to replace
    President:
  • Refrigerators Master
  • 2,651 Answers
If the unit is stuck in a defrost mode you eould have no cooling things in freexer would be defrosting quickly
Posted on Mar 13, 2008
SOURCE:
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
The freezer cools half way top, below is warm.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator is not cooling properly. We have turned the setting to coldest and it is still too warm. The freezer seems to be working fine.
Top of Form
Jul 08, 2011 | Refrigerators
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Refrigerators Logo
591 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
