Question about Dell Dimension 2400 PC Desktop
Can u help me?
I want to slave my hard disk in another computer i don't know how i make it slave.
  • bezi Mar 13, 2008
    my system couldn't detect my HDD
  • bezi Mar 13, 2008
    i already did what i can to do to set my jumper settings according to the diagram on the HDD but still my system give me the msg both my master and slave discs are not found
How to lower internet browser
Posted on Mar 13, 2008
  • 35 Answers
To slave a hard disk, first you must set its jumper setting to slave because if you dont set it, your system will be on chaos because the system will be confuse who will be its master harddisk. so after setting it, power on and check at its BIOS if your new hard disk is registered to the system.
  • Anonymous Mar 13, 2008
    what is the connection of your hard disk? is it IDE( ATA) or SATA? have you checked your system's BIOS?
SOURCE:
I need to know the jumper setting for my hard drive to set it to a slave
Here is the jumper settings for Samsung hard drives. Assuming that your hard drive is bigger than 32GB you have to use the "General Pin Setting"
Note that after changing the jumper, it's suggested to partition and format your hard disk drive.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Samsung Computers & Internet
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
How to make master and slave
"Now for a refresher course on hard drive connections. When connectingmore than one hard drive to a computer on the same IDE controller, yougenerally have to assign one as the primary (master) and one as thesecondary (slave). You do this by changing the jumpers on the harddrive next to the power connector. Normally, the drive will have adiagram to let you know which jumper should be set for a master driveand which to set for a slave drive. You'll notice in the picture belowthe jumpers are circled on the end of the drive and the top of thedrive shows the diagram to follow."
Go here http://www.pchell.com/hardware/masterslaveorcableselect.shtml for more..
Dec 06, 2009 | Computers & Internet
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Primary Master/Slave Hard Disk Error
Honestly, this is the best software I've used for file recovery:
http://www.ontrackdatarecovery.com/file-recovery-software/
It's a bit pricey, but if your data is important, it's worth every penny.
Hope this helps!
Mar 28, 2009 | Audio Players & Recorders
Dell M60
what you mean hard drive?
did you mean hard disk ok!
theres a jumper at the back of the hard disk
so a mother board can recognized if one your hard disk
may set into master or slave
set the jumper one of your hard disk into slave
and then try to connect
or email me [email protected]
Sep 18, 2008 | Dell Precision M60 Notebook
Connection for virused harddrive to fully protected hardrive
If you examine the hard disk you should see on the labels the jumper positions for setting it to slave. You will then need to attach the slave disk to the power and data cables inside your friend's computer.
Apr 16, 2008 | Computers & Internet
Installing 2 hard drive
if ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Mar 20, 2008 | Computers & Internet
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Dell Dimension 2400 PC Desktop Logo
54 people viewed this question
Ekse
Clive
Clive
