It sounds like you have a problem with what is called "phase cancellation," which is something complicated that happens with audio when the left and right channels get out of sync and cancel out all of the common sound between the two channels. This can happen with bad speakers, a faulty output jack, or just failing to plug in the speakers all the way - it's also used (trivia!) constructively in the studio to create interesting effects on sounds.
http://en.wikipedia.org/wiki/Phase_cancellation
I don't think that you are actually experiencing a problem with WMP, but with your speakers or possibly your sound card. Here's what to do:
First, while music is playing, check and make sure that the speakers are well connected. Double check where they plug into your computer and ensure that the jack is inserted all the way. If they appear fine, flex the speaker cable a bit near the adapter...if you hear the sound change in any way (not including clicks or pops, really), the problem is most likely a short in your cable. Replacing the cable or speakers if necessary will solve this. If this doesn't help either, turn the speakers off and unplug them.
If you have an iPod or Discman lying around, plug it into the speakers and turn it back on. With music playing does it sound better? If yes, probably your sound card is damaged. These can be replaced very inexpensively. If it still sounds just as bad, your speakers are probably broken. You can try a new cable if it is A) removable and B) you have a replacement or don't mind buying one. Otherwise the speakers will have to be replaced.
