Question about Spidem Trevi Automatic Espresso Machine
My machine does not seem to want to prime.
I stored this machine away last year.I drained what water I could from it.while trying to put it back into use,I noticed that it would not accept(****)water from the reservior.All other functions seem to be fineAny solution to this problem?
So, no water or steam is coming out of the machine? How long are you letting it heat up? I have a Spidem Trevi--semiauto kind--I have to let it heat up at least 1/2 hour. Otherwise no water comes out through the grouphead.
Also, be sure to use water that isn't "hard". Hard water is a killer on espresso machines! Have you descaled the machine ? I would try that as well.
Posted on Mar 14, 2008
Keurig special edition b60 prime problem? My keurig now has the prime message showing up. I have ran through all of keurigs trouble shooting and none of it has worked. The prime message will go away...
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Apr 21, 2013 | Coffee Makers & Espresso Machines
The word "prime" shows up in the window and I
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101';
Sep 17, 2011 | Keurig Special Edition B60 Coffee Maker
It won't drain away water.
take drain hose put in pail at ground level if it drains trouble with pump
if no drain try
put a hose in drain pipe hose force water back into machine then see if it drains the plumbing of machine has to cleaned spin tub shall have to be remove to clean
Jun 12, 2011 | Washing Machines
Top Load Roper Washer 7 cycle 2 speed W10330949A Bought 2 months ago ..not hooked up right away either While machine is in the washing cycle...water keeps draining out and refilling. Also Water is...
The drain hose needs to be higher than the top of the water level and yes, there needs to be an air gap so the drain does not siphon. As far as temperature, the machine will automatically put in cold or hot water depending on the temps selected. You cannot get straight hot water from this machine...that is by design. You will have to live with the temps you are given...I know, it sucks!
Kelly
Mar 21, 2011 | Washing Machines
My coffee pot has an error saying PRIME, and will not work. Could you tell me what the problem is?
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
Mar 12, 2011 | Keurig B60 Coffee Maker
I have a 1 1/2 hp Flotect irregation pump for my
there is a drain plug that can be unscrewed , sometimes they can fall out or get lost, if this happens you will not be able to prime. Also when you stored it for the winter, if you didn't drain it all the way did you store it some where the water inside the pump could of froze and broke something inside? When pumps go bad they just stop working like this. IF there is a leak under ground in the pipe it will not build pressure and prime. Some times you need to check the main control valve to make sure its opening. you can try taking a hose and filling the sprinkler system at a sprinkler head then turning the pump on.
Apr 26, 2010 | Plumbing
New Keurig B140 will not pump or prime
Oct 30, 2008 | Keurig Special Edition B60 Coffee Maker
Machine loosing water
the pipe inside the washer where the water goes from the tub to the pump might be loose
Feb 12, 2008 | Washing Machines
Can't prime new machine
brand new machine you put water in the container prime it with turkey blast open the valve on the side off machine and it still does not work tank good for warranty cheers
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Spidem Trevi Automatic Espresso Machine Logo
185 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
