Question about Sony KV-27V55 27" TV
Distorted Screen The screen on our television is stretched very strangely like a mirror from a funhouse. It starts off small in the middle and gets very stretched out on the edges. I can't find anything on the remote that changes the dimension. Any ideas?
    Problem Solver:
  • 13 Answers
It sounds like the the power supply or the horizontal circuit is faulty, it is very likely you must take your TV to a professional repairer.
Posted on Mar 13, 2008
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
My screen image is concave, like a funhouse mirror. The image is distorted at the top and bottom of the screen. Any suggestions?
it is called pincushion circuit. either the diode went bad, the capacitors, or just maybe a simple solderond the bad connections.
Nov 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thin bar in the middle of the screen showing the picture
You should get the vertical IC checked starting with checking the supply voltage on it. This is a small flat IC attached to a heat sink with about 9-11 pins. This tv model should carry an LA7837 or an equivalent IC. If supply is present, check with means of a magnifying glass for dry solder joints on it. Resolder the pins on this IC if necessary and should work out fine. Model tends to suffer from this problem.
Aug 19, 2009 | Sylvania SRT2232S 32" TV
Hitachi 46'' Rear Projection TV has distorted picture
Make sure no one pushed the front screens in a little. That will cause exactly what you have. I've seen cases like this where someone would move there set with one had pushing on the front screen and dis-lodging them creating that problem... Hope this helps.
Mar 08, 2009 | Hitachi 46UX50B 46" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Plaid Screen
The problem is likely with your seine board or another video board. It will have distorted video/colors and you will see copies of the image in random sizes/places around the screen. If the toshiba menu is distorted it is in later stages of video, if not then earlier. More info will narrow down exacly which board. You can try reseating the LVDS cable, the computer looking one in the middle of the tv. It goes from the video board to the light engine. Unplug the tv and take off the back. The cable is usually white and has a D-type computer like connector with buttons or screws to unlock.
Dec 06, 2008 | Toshiba 50HM66 52" Television
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
