Question about HP PSC 2175 All-In-One InkJet Printer
I need a disk
To add to my new comp
    Genius:
  • 3,587 Answers
No worries..go here, enter the hp logo, add model number, select operating system, should be hunky dory
Posted on Mar 13, 2008
A virus called personal security has invaded my wifes laptop and wont allow entry to anything to uninstall/remove, or even access the internet
HI,
You will have to boot with a antivirus boot rescue disk.
If you have an antivirus installed and you made such a disk, use it.
Install an antivirus. If you cannot do this in the normal mode, restart the comp in safe mode. Press the F8 key when booting and you can enter that mode.
After cleaning, you can proceed.
If you have no rescue disk, you can try the rescue disk by drweb antivirus. It is created new everyday, so get it from the website. download and burn on another pc then use it with your wives laptop.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Computers & Internet
I want to use a 80gb hdd out a xbox ,for my comp
The xbox uses a different filesystem than a PC. If you just want to add the hdd to your pc, you will need to format the hard drive so that it uses a filesystem the pc can recognize. For a windows XP/Vista system, this gemerally means NTFS filesystem. Keep in mind that this will destroy all existing data on that hard drive such as games and saves, so be sure that's what you want to do. You should be able to format the hdd from Administrative tools -> Computer management -> disk management and search for disk 1 or something similar. Take care not to format the disk holding your C: partition.
Sep 19, 2009 | Computers & Internet
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
Need to restore a dell 2400
to reinstall windows, you would have to cantact dell for a new windows disk, which may cost you a few dollars.
Dec 29, 2008 | Dell UltraScan P1110 21" CRT Monitor
Startup repair failed. cant get to startup screen
did you back-up your important files?, if you did, then you need to reformat your hard disk drive (hdd) and reinstall new system.  but if you didn't backup your important files, ask for help at the service center near you, cause it need another hdd to backup some files.  then if you have nothing to lose on your hdd then go ahead to reformatting. sometimes that error occur when it didn't undergo proper shutdown
Dec 14, 2008 | Dell Dimension E521 PC Desktop
Cant boot up comp
YOU DONT NEED BACKUP DISKS AS THEY WONT REPAIR THE STARTUP PROBLEM .. THEY WILL ONLY SAVE YOUR DATA FROM GETTING LOST .. WAHT YOU NEED IS A BOOTABLE XP OR VISTA DISK FROM WHICH YOU CAN REINSTALL THE WHOLE OPERATING SYSTEM AGAIN
Sep 14, 2008 | Acer Aspire 5050-3242 Notebook
Why display "disk full" or "Wrong disk" and the disk is new
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
Nov 19, 2007 | Teac (CDW552GA02) (CDW552GA02/10PK)...
HP PSC 2175 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
