Question about Nokia 6300 Cellular Phone
Nokia 6300 Hi, My nokia 6300 goes to standby mode when i try to capture. when i changed to video mode and start to record , it says "unable to save file". So i changed the memory card and put another, then no problem , it works. So i put te problem making memory card to another nokia 6300 , it works there with no problem. So I put back my old memory card to my phone and tried, again the problem exists... Wierd problem..pls help me... Thanks jank
  • jankoben Mar 13, 2008
    Thanks
    I will try that
    President:
  • 1,950 Answers
Try reformatting the memory card with a PC and card reader. This could solve your problem. Make sure you back up important data from your card before doing so.
Posted on Mar 13, 2008
  • Damen Wong
    Damen Wong Mar 13, 2008
    I hope it works out for you.
SOURCE:
My windowsHTC HD2 video recorder wont work, it says "Unable to capture video, Disk Full" This is incorrect!, as i have space. I have used Clean Temp, I have freed up space and deleted extra...
Hello, The HD2 only has 1024MB of internal storage, the problem you are having is that the video recorder is saving the files to your internal memory. Try changing your settings in the options menu to 'save to sd card" .You will need to use the 16GB sd card you received with the phone. Good Luck
Mar 05, 2011 | HTC Cell Phones
I am using nokia 6300 but i have a problem about one wee ago when i started my cam its show that cam is on standby and i am unabel to capture a picture
Please check if the memorry is full in you phone if so copy save and make space.
If the fault is still present then a software issue might be the reason for the camera to click on.
check this out,
Aug 25, 2010 | Nokia 6300 Cellular Phone
My camera goes to standby mode automatically and shows couldn save the file for video:(
Check if your memmory card is full or if the default folder for saving your videos is on the phone memmory ( You can check it by taking the "options" in camera mode ) Or try switching off your phone and on it again
Oct 03, 2009 | Nokia 7373 Cellular Phone
Whenever i try to take photo the camera turns to
probably ther isn't enough space left in ur phone memory try deleting to clear up unwanted stuff.
If there is space both in ur phone as well as memory card then rearrange all items in the memory card to specified folders. like if there are items that show outside the folders then dump them into the folders and this will solve ur problem.
This is strange but try it all will be ok. Next time when u want to format ur memory card see that u do it with the phone itself and not through a PC
Jul 01, 2009 | Nokia 6300 Cellular Phone
Error line is coming & going
Nokia N97 32GB unlocked ( Brand New )
Specifications
* Size: 117.2 x 55.3 x 15.9 mm* *18.25 mm at camera area
* Weight: Approx. 150 g
* Memory: Up to 48GB (32 GB on-board memory, plus 16GB expansion via
microSD memory card slot)
* Display: 3.5 inch TFT with up to 16 million colors nHD 16:9 widescreen
(640×360 pixels)
* Talk time: Up to 320 min (3G), 400 min (GSM)
* Standby time: Up to 400 hrs (3G), 430 hrs (GSM)
* Video playback: Up to 4.5 hours (offline mode)
* Music playback: Up to 37 hours (offline mode)
* Image capture: Up to 5 megapixels (2584 x 1938) JPEG/EXIF (16.7
million/24-bit color).
* WiFi and HSDPA
* DVD quality video capture and 16:9 display
The Nokia N97 32GB is made in Finland and it is the leading phone in the
Market, beating the Nokia N96 16GB and also the apple 3G 16GB..
Nokia N97 32GB is touch screen and is one of the Smartest technology.
Be one of the first to have this phone, We have sample units available for Sale..
Feel free to contact us, we are always online to give you a reply...
NOTE:
If you send us a mail today, we will reply you today.
[email protected]
May 14, 2009 | Nokia 6300 Cellular Phone
Video file (NOKIA 6300)
You need to use Nokia pc suite to convert the file to the proper size.
Mar 16, 2009 | Nokia 6300 Cellular Phone
Stand by mode
Check camera settings once... There u need to select storage option as memory card... try this one...
Dec 25, 2008 | Nokia 6300 Cellular Phone
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
