Question about Sony Playstation 3 (PS3) Console
Ps3 Optical output??
PS3 I accidentally changed my optical to the digital out/optical out and now I can't see **** to change it back to be able to play. Know how to fix it?
  • thedude182 May 11, 2010
    do you just mean you have changed the sound to output via the optical cable? thats easily fixed by entering the sound options menu.
    or do you mean you have acidently changed the output resoloution to something higher than your TV can support?
    Problem Solver:
  • 16 Answers
If u changed it to HD then when u turn it on hold down the power butten untill it beeps 2 times then u should be able to c
Posted on Mar 16, 2008
There is no sound coming through my HDMI/DVI cable. is there any other way to get sound?
Try going into the audio setup of your PS3 to make sure you have it set to send audio down the HDMI. The PS3 allows you to send the audio down the HDMI, standard, or optical, but you have to change the settings.
Along the same lines, you can use an optical cable to run it to a receiver (or your tv if it has an optical input). Just remember to change it to the optical output.
I don't have the PS3 in front of me right now, but go to this link and it will explain it to you:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Thanks for reading and good luck.
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
I used an optical cable from my ps3 to my receiver but no sound
change the sound output to 'optical' on your ps3
system menu
Sound
Sound output
(select optical)
I think you may have to change the channel on your AV reciever to Input or audio or something
Jul 08, 2009 | Audio Players & Recorders
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
Digital audio output not working
There is a setting in the setup menus of your PS3 to enable digital optical output. You will also need to go into the setup of your amp or AV receiver to tell it that you wish to use digital optical audio, and associate it with the PS3 source selection.
Jul 16, 2008 | Sony Playstation 3 (PS3) Console
Ps3
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
215 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
