Question about LG Cell Phones
Lg trax will not sleep
Lg trax will not turn to sleep mode. drains my battery.
No i didn't.
but you guys ****.
stop trying to sell me your service and fix my problem already.
I'm sure you can make money just off the advertising (word of mouth) alone.
thanks, but no thanks.
i'll figure it out by myself.
Posted on Mar 13, 2008
My LG optimus keeps getting stuck in sleep mode. When I turn it on it seems fine but once it enters sleep mode it won't turn back on. I have to restart the phone to get a picture again. Any tips?
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
Jan 02, 2015 | LG Cell Phones
How do I stop the anti-theft device red blinking light? Car is off and locked and from the window can see the red light blinking.
the red light drain 0.001amp. from you battery.need 1000 hour to drain 1 amp. test the battery if is any good. do drain test on the car.rust and short will drain battery overnight.after market equipment,light in the trunk or glove box, under hood light etc. disconnect the battery and install amp meter. do the drain test. your computers uses 0.2-0.4amp when sleep.anything over 0.5-.6 amp is bad. after you connect the amp meter give 1min. to turn all systems to sleep mode.Is normal the first minute to be high drain.
ones you know something is wrong disconnect the fuses one at the time and note if any changes. if the fuse you disconnect turn the amps low note what system is connected to the fuse and you will know were is the problem
Oct 24, 2014 | 2003 Oldsmobile Alero
Why doesn't turn my monitor on back from sleep mode?
If from Russia, 8-800-200-76-76 (Russia)
8-820-0071-1111 (Belarus)
This is Official LG Support No.
Apr 28, 2014 | LG L1730S 17" LCD Monitor
Why wont my L9 to into sleep mode
Hi Orlando,
I have this site for you where you can download a software where you can set up deep sleep battery saver for your phone. Hope it helps.
Deep Sleep Battery Saver Pro
Apr 28, 2014 | LG Optimus L9
Battery status incorrect
This recalibrate's the battery.
Charge the battery completely. Monitor the battery indicator, which is usually found that the bottom of your computer screen, to check if the battery is already fully charged.
Plug off the power adapter and use the laptop until the battery is completely drained. To drain the battery faster, run several programs at once and keep the contrast of your screen to its highest levels. Turn off all power-saving features as well. Turn off sleep mode.
Make sure that the battery is totally drained by waiting for your laptop to shut off or go into sleep mode automatically because of very low battery charge.
Plug the power adapter again and charge the battery again completely. Once this is done, restore the power-saving features and adjust the contract settings of your screen to normal.
Apr 08, 2013 | Dell Vostro Computers & Internet
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
Uniden Trax 5000 - unable to use Trax Central
Had the same problem with Trax Central software. Ended up successfully using Naviextras Toolbox application. https://www.naviextras.com/shop/portal/downloads
Still don't know what, if any, extras on the Trax Central software. I tried to get it to run on 3 XP boxes and 2 Windows 7 boxes. Gave up in disgust. Good one Uniden.
Mar 22, 2010 | Uniden GPS
Battery drains in sleep mode
most GPS will drain in sleep mode unless on some slow charge. Everything is actualy working inside except the screen Like the TV standby.. no picture or sound but chews up the power
Jul 19, 2009 | Garmin iQue M5 GPS Receiver
Battery life
your phone should be in sleep mode if you are not using it. if it on all the time it will drain the battery real fast. Change your battery usage setting. I had the same problem.
Dec 23, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
