Nokia 2600not charging problem
Hello
Your phone is not charging because of the following problems;
1.The Charger; try charging your phone with another nokia charger to see if it works,if it does then the problem is from the charger and you should replace it
2. The battery; Get another battery(compatible with your phone),insert it into your phone and charge it to see if it works,if it does then the problem is from your battery and you should have it replaced
3.The charging port; If you have tried 1and2 and your phone still isn't charging then the problem is from the charging port and it should be fixed or replaced.
Thank you for visiting fixya
Change the outlets you *******
Nokia chargers are pretty notrious so I recommand you check the charger first :)
first check for the charger plugged correctly..check the pin is fixed correctly,, or try to switch off & charge or if still prob exist pls change the charging ic which ll cost around 2$ usd
