Question about Kenmore 24032\24036 Top Load Washer
Kenmore 23012, spin cycle problem
Went through cycle, pumped out water, would not go into spin cycle.
I can turn the tub by hand, but seems to get hung-up at points.
Did not fill tub with water to see if agitator works as I do not want to fill
with water and have to empty.
If I turn directly to any spin cycle, motor hums and as it is trying to spin
the drum. tipped over and has a closed gear assembly and linkage
between motor and assembly.
Any ideas to point me in the right direction would be appreciated.
This sounds like a broken coupler gear. I'm having the same problem with my Kenmore-80 Series. The machine fill up, pump out, but when I try to spin I get nothing and the I can hear the motor humming/grinding. I've heard the coupler gear is not expensive $35 or so and the repair procedure is not difficult, but I can't locate how to fix it. If you find any additional information, please send my way. I don't want to pay $150 or so to have it serviced.
Posted on Mar 13, 2008
  • Anonymous Mar 22, 2008
    I purchased a coupler for $15 and installed. Problem (washer fills & pumps out, but will not agitate nor spin) solved by installing the new coupler.
SOURCE:
On the spin cycle washer thumps and spins fast
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load direct drive Whirlpool / Kenmore washers use a number of springs and plastic vibration pads between the base and tub to control vibration.
It's possible that one or more of the springs or pads has come loose or broken.
See the following for how to remove the cabinet to gain access to the springs and check them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Nov 25, 2009 | Kenmore 23012 Top Load Washer
Kenmore Elite Quiet Pak 4 less than three or four years old. Went through a "white cycle" but wouldn't finish the last spin. Had to hand wring out clothes. There is still water in the machine.
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 19, 2009 | Kenmore Elite 45986 Front Load Washer
Not draining water from tub-goes through cycle but water remains in the tub at end of cycle
I had a similar problem. The pannel under the door can be removed by 3 screws. After that if you look there should be a water pump there (it will have a drain hose from the washing machine (black) and a drain hose that leads to the back of the machine). There is a white srew cap that is a filter. Take the cap off and then remove the filter and check for clogs. Replace the filter and turn machine on drain/spin cycle. Put your hand on the pump to ensure that the pump is working. If so you should be all set.
Aug 18, 2009 | Kenmore Elite 45986 Front Load Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Kenmore 23012 / Clothes still wet after spin cycle
Remove end caps from console (put fingers behind top and pull towards you. small flat head may be required). and the 2 phillips screws behind them. Pull console towards you and up, it wil flip out of the way. Unplug door switch connection on top rear right of cabinet (3 wires). Put flat head STRAIT DOWN into brass looking clips and push forward. They'll pop out. Lean cabinet towards you and shine flashlight inside. Look for oil splatter about 8" up from bottom. If there's oil, then the trans has leaked oil into the clutch and it's slipping. Repl. transmition and clutch assy. If you see oil, it's cheaper to buy new washer. Trans and labor is about 400
Mar 17, 2009 | Kenmore 23012 Top Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 09, 2009 | Kenmore 46462 Front Load Washer
My kenmore elite calypso-clothes still wet after spin cycle done
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 06, 2009 | Kenmore Elite 45986 Front Load Washer
Spins slow or not at all, in the spin cycle.
Remove the water pump and check for a blockage in the pump.
If no pump problem replace the brake and the drive coupling.
Feb 22, 2009 | Kenmore 23012 Top Load Washer
Kenmore front load doesn't seem to final spin(real fast)
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
201 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
