Question about Refrigerators
Fridge seal repairs
I would like to replace the door seal to my hoover orchid collection 410L fridge/freezer however I do not know where I can get the seal from, any ideas?
We sell these seals online at http://www.doorseal.com.au
We also have online instructions on how to fit them.
Posted on Nov 12, 2008
    Scholar:
  • 178 Answers
Check for the seal replacement on www.marcone.com.
Posted on Mar 14, 2008
SOURCE:
Fridge Hoover Orchid Collection model # B41tf need the manual please
Try Googling (hoover)(B41tf)(manual) without parens.
Dec 15, 2017 | Refrigerators
Hoover HFOE54B fridge ice box door catch does not close properly.
The door needs adjusting as the seal is usually magnetic.
Jul 16, 2017 | Hoover Refrigerators
I have a Hoover Fridge freezer and my fridge is really warm inside and the freezer is not freezing the food in the top drawer but it is keeping the food a bit cold. What could be wrong with it?
It could be
- a faulty thermostat
- a loss of refrigerant through leakage
- a very poor sealing door gasket
If the fridge is old I'd say you will need to replace it.
Nov 13, 2016 | Hoover Refrigerators
Looking for a rubber to fit around the door of the fridge , do you know where in australia they can be bought . thanks . julie herring
Here is a link to an Australian supplier of Hoover fridge door seals:
http://www.doorseal.com.au/fridge-seals/hoover
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Not sure if you can pick it up locally yourself, but you can certainly order one online and have it delivered. Just look for your specific model number at the above website.
Good luck.
Mar 21, 2011 | Hoover Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
Making Modifications to my Hoover Orchid Collection 480L fridge
if it is a fridge and not a fridge freezer, then there should be no problem in drilling a hole thro the side
Aug 21, 2008 | Hoover Refrigerators
Refrigerators Logo
328 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
