Question about RIM BlackBerry Pearl 8100
Palm Treo 700P In Death Spiral
I have a Palm Treo 700P on Verizon that is not working now.
Physically it is in great shape, but it has gone into what some people refer to as the "Death Spiral." It constantly reboots itself non-stop, over and over again. The treo will start up, get to the Access Powered screen, which will stay on for about one second, and then automatically reboot itself, over and over again. It never makes it past the Access Powered screen.
I have done Soft Reset, Hard Reset, and a zero out reset, all to no avail. I have talked with a representative at verizon (my carrier), and they said that basically there must be a start up registry error and that it is now "useless."
The Treo is out of warranty, so I can't get any help from Palm directly.
Is this something you have experience fixing? If so, can you give me an estimate of the cost to repair?
Thank you in advance,
Mark
  • 1 more comment
  • wcwnet May 22, 2008
    exactly the same issue, was using the phone ended the call and was about to place a call when it started the Death Spiral.
    All reset options have no effect. Putting the battery in while holding
    the sync button will produce a color pattern but no functions are
    available.
    I did call Palm USA tech support - apparently they are aware of the
    issue but have no free solution that they would offer me - for $199 I
    could send it to them for repair.
  • jonnytest Jun 21, 2008
    Same exact problem with my 700p as well. I have tried every kind of restart there is with no resaults.
  • cattwmn Oct 25, 2008
    I have the same problem. Tried to access one of the applications on the phone and it started the endless "spiral" of flashing on and off with only the ACCESS POWERED screen appearing. Luckily I've only had this phone for 6 mos. so Verizon is sending me a new phone since I'm within warranty. Would still like to know how to solve this problem should it happen again.
    Good Luck.
I had a similar problem, did a hard reset, reloaded my applications, and the problem came back. I finally narrowed it down to "clock" related apps. I had several, so I deleted most, and the problem went away.
Posted on Nov 04, 2008
I just encountered exactly the same issue.
Was using the phone ended the call and was about to place a call when it started the Death Spiral.
All reset options have no effect. Putting the battery in while holding the sync button will produce a color pattern but no functions are available.
I did call Palm USA tech support - apparently they are aware of the issue but have no free solution that they would offer me - for $199 I could send it to them for repair.
Posted on May 22, 2008
My Palm Treo 700p won't send email although it receives email just fine.
plz check ur network setting if dere is so many congigration setting of differnt network....... than delete all ,,except the setng u require... switch onn and off ur mobile ur problem wll be solved.........
Mar 19, 2010 | Palm Treo 700p Smartphone
Bluetooth connetion with Verizon Treo 700P
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne (www.palm.com) so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Aug 18, 2007 | Garmin Nuvi 660 GPS Receiver
I replaced the screen in my palm treo 700p and now the phone works but the screen wont come on.... what do i do?
Can you hear it ring when u try to call ur number using a different phone? If yes, maybe it isn't aligned properly or check the connector.
If no, the software is crashed, it needs a software reflash/reprogram
Dec 15, 2009 | Palm Treo 700p Smartphone
Cannot get on the web
Which model, The 700wx, 700w, or 700p?
Which Carrier? If other than the 700w (in which case your carrier would be Verizon) then which of the
following carriers do you use: [700wx] Alltel, Bell, Tellus, Verizon or Sprint, [700x] Alltel, Bell, Tellus, Verizon or Sprint, Cellular South?
Take it to your provider and have it activated for Web Enabled Services.
Apr 08, 2009 | Palm Treo 700p Smartphone
Calendar
Try soft resetting your Palm Treo and sync it with a latest version of Hotsync and your latest calendar events on your computer.
Hope this helps!
Nicholas
Jan 26, 2008 | Palm Treo 700p Smartphone
Nonworking keys on Treo 700p
make sure first of all that there arent any screws missing or loose in the back by removing the battery cover....thats can cause the keypad buttons to not have a good connection to circuit board... if thats ok then you can use a toothbrush and some alcohol (denatured alcohol if possible) to rub and clean the keypad. If all that fails, I know that Sprint offers repair for their phones.
Nov 11, 2007 | Palm Treo 700p Smartphone
Treo 700p stuck in network search...T
Verizon suggested a hard reset on my 700w for the same problem. (Hit soft reset and power/end button at same time and hit up on keypad when prompted to reset everything and reboot)
you will loose all of your features but they say it fixes 5/10 times...
It did not work for me but I wanted to share in case.
Oct 26, 2007 | Palm Treo 650 Handheld
RIM BlackBerry  Pearl  8100 Logo
285 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
