I just installed a new modem on my Dell 4400 Dimension. When all was done, my computer no longer recognizes my Olympus DS-3000 when I plug it into my USB connection for the Dictation Module, where I download my audio files. During the setup for the new modem, it updated my USB drivers. Could it have messed up something? I have tried a lot of things, and nothing is working. Truth in advertising: I am not very computer savvy.
  • 148 Answers
Try another USB port and make sure the recorder is not on HOLD when you connect it to the computer. DSS should open automatically. Good Luck
Posted on Mar 13, 2008
    Sergeant:
  • 317 Answers
You need to run device manager.. and removed auknown device file... then restart .... if you need driver try this web www.driverguide.com
SOURCE:
I have a dell dimension 3000. I wiped the computer, installed OS disc, but it says FAIL every time I try to do anything with the utilities & drivers disc. I also have no internet because it won't...
Right click on My Computer>Manage>Device Manager>does your CD-ROM have a yellow ? or ! on it?
If so, then you somehow need to install a driver for your computer to recognize your drive. If you can get an external CD-ROM that connects to a USB port, maybe you can install the drivers that way. Once that CD-ROM is working, then you can get the drivers installed for your modem. Hope that helps!
Aug 04, 2011 | Dell Dimension 3000 PC Desktop
The indicator lights on the back of my dell dimension 4400 are g g g y.it was working fine now wont boot up.
Other failure.
See "Contacting Dell" in the Owner's Manual for instructions on obtaining technical assistance.
Here is the info straight from Dell. Looks like you will need to call dell tech support for further assistance. They are pretty good about giving support even if the system is no longer covered under warranty.
Dec 28, 2010 | Dell Dimension 4400 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
New, second modem won't recognize modem
You probably need to install network adapter driver on your new hard drive.
Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
Dec 27, 2009 | Dell (S423) for Dimension 8100 (3F546)...
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
External HD not recognized
right click on My Computer then go to Manage. select disk management and assign a letter to your external drive. close out and reboot
Nov 24, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Most of the Dell cases can be opened without tools, it should not be too difficult.
Here's the link to the Dell 3000 support site.
V=
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
Take a look at "Removing the Cover"
Next click on then "Removing and Installing Parts" and then click on "Cards".
You should be able to replace your modem with any PCI modem compatible with your operating system. Go to Bestbuy or Officemax and tell them what you're looking for and they'll help you choose a modem that is compatible. Just follow the modem manufacturer's directions to install. Sometimes they want you to install software then hardware, sometimes the opposite. Just follow their directions.
I hate to beg, but many people don't realize we don't get paid for this, we just like trying to help. I hope you'll take a moment and rate this solution if you found it helpful.
Dec 30, 2007 | Dell Dimension 3000 PC Desktop
Returning To The Original Operating State
you may find that you have two partitions on your hard drive showing as a seperate drive in my computer, here there is normally a backup of your pc's initial setup.
There should be a wizard somewhere on your programme files to help you with the backup restoration process, but make sure you save anything important to a cdrom before you start as the system will be completely formatted and installed as new.
Nov 23, 2007 | Dell Dimension 3000 PC Desktop
Open Questions:
Computers & Internet Logo
62 people viewed this question
Ekse
Alun Cox
