Question about Dishwashers
There is no power going to the dishwasher. It worked perfect 2 days ago and now it won't work. Checked the fuse and the plug. Now what. 2 yrs old GE QuietPower2.
  • 99 Answers
Check the transformer from primary winding to secondary,maybe ist already defective.check the voltage in the secondary,check the switch .
Posted on Mar 13, 2008
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
1993 Dodge Spirit Promble, died, lost power,We checked,air filter,sparked plugs, gas line fuse,roter cap, belts,battery,prime it,gas line link age, new gas, seems to firer, but acts as if its not geet
If you expect you old reliable to maintain perfect tune-up status after TWO years, you are expecting too much, it could be many small things. Do a complete inspection before changing so many parts.
Apr 25, 2012 | 1993 Dodge Spirit
I have a GE Profile cooktop jp930 (less than 5 yrs old) that appears to have lost all power. It was working fine when I turned it on and about 10 minutes later it lost power. I checked the fuse box and...
first check if power is getting to the cook top(there should be a box outside where the wire goes in. After that you have to check if the power makes it to the main board/connector to see if the individual burners are working. My guess is that there is a loose wire at the connection they redid when you redid your counters
Aug 10, 2010 | GE Profile JP930 Electric Cooktop
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
May 14, 2010 | GE Profile Harmony DPGT750EC Electric...
Upper spray arm not working ge quiet power 22 yrs
Often they will not spin because there is stuff inside that plug the holes...
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 17, 2010 | Dishwashers
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Trouble with my Protron PLTV3250
Power supply is bad get one here.
http://www.power-on.com/lcd194-3f.html
Only $60 not $100-150 like other places.
Jul 27, 2009 | Protron PLTV-32 Television
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Dec 09, 2007 | GE 24 in. GSD3620Z Built-in Dishwasher
Dishwashers Logo
194 people viewed this question
Top Dishwashers Experts
