Question about Canon BJC S300 InkJet Printer
Bliking light my light is blinking gren orang 7 times and then there is a 2-3 sec break can you help ?
  • Anonymous Mar 03, 2009
    how do i reset the waste tank counter alert?
The problem is waste tank counter alert.
I have the same problem, we need to make the waste tank counter reset, but I have tried it with no success.
mguahy
Posted on May 09, 2008
IT'S SUPOSED TO KEEP PRESSED SHUTDOWN BUTTON BEFORE PLUG THE POWER WIRE AND THEN, KEEPING THE SHUTDOWN BUTTON PRESSED, PRESS THE RESUME BUTTON, WAIT MORE OR LESS TWO SECONDS, PRESS AGAIN THE RESUME BUTTON AND THEN FREE BOTH BUTTONS. THIS RESET THE WASTE INK COUNTER, BUT FOR ME IN A FEW SECONDS, THE ERROR IS BACK AGAIN. HOW CAN I REALLY CLEAN THE WASTE INC RECEIPIENT?
Posted on Jun 17, 2009
SOURCE:
My sharp aquos lc52d65u dosent turn on. the power light blinks 5 times, stops for 1 sec, and start bliking 5 times. can you help me please.
It is possible that there is a failure of some components in the main board or a possible break of connectivity. You must be familiar to open the set and have some basic knowledge of the electronics inside. Use a good source of light to check for physical indications of burnt out, dry solder joints or connections.If after soldering there is no result then you will have to take a voltage check and see for any short in the main output drive, short in the capacitors. Take your time to make a good check for open circuits as the feedback is required for the smps to power on. Hope you get this right. Good day
Aug 02, 2010 | Televison & Video
Printer keeps on flashing E-5 and is not printing out anything
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon BJC S300 InkJet Printer Logo
470 people viewed this question
Clive
Clive
old marine
old marine
Ekse
