Question about Xerox WorkCentre XD100 All-In-One Laser Printer
High pitch squeal, not picking up paper
I have a XL2140DF model, which is basically an XD100 model. I've got some gear "clicking" when the motor is spun by hand, but when powered up you get a very loud squeal for about 15 seconds. Then the motor stops and so does the squeal. If you press "S" to make a copy, it makes a squeal for 15 seconds and does not grab the paper and displays a "P", for either out of paper or paper jam - both incorrect. I believe a gear is broken. You also smell a faint smell like maybe burning plastic. I disassembled the back of the copier and carefully examined all gears on the metal plate that drives the toner, drum, and fuser. There all appear to be intact and functioning ok. Before I buy a bunch of gears to replace a questionable gear, can you tell me which gear to look at or where to look for another problem? I was thinking it was the fuser drive doublet gear, but it appears okay, it does click when turned backwards by hand. But I don't think this gear has anything to do with picking up the paper.
  • parttimetech Mar 13, 2008
    I think the seized mechanism is caused by 2 gears that aren't sync'ing on the gear train. 2 different gears drive the drum cartridge. Both gears are synced together. I took the back of the copier off again and reexamined the gear train, and experimented by engaging the cartridges on it and turning by hand. I found a 55 tooth/19 tooth gear that drives the drum along with another gear. Well, the 19 tooth gear is "chewed up a little", possibly enough to lose the sync, and cause the squeal, seizing, and plastic "burn" smell I mentioned earlier.
    Luckily, I have an XD100 copier, that use both the same fuser and drum as this broken copier. I swapped the drum and fuser into the good copier, from my bad copier. Both the fuser and drum worked in the good copier. So I've eliminated those parts.
    So, I hoping this gear solves the problem. All other gears turn fine, and engage the paper feed, etc.
    Thank you for your help. Aloha.
    Genius:
  • 3,587 Answers
It's not the gear..you are having a seized mechanism, most likely from something stuck in there.
Posted on Mar 13, 2008
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
My Hp 1200 laser printer makes a high pitched squealing noise and I have to pull the plug out to stop it.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 13, 2014 | HP LaserJet 1200 Printer
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
Sep 11, 2009 | HP Hewlett Packard LaserJet 1600 Printer
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
154 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
