I've just put in all new inks and now ther is no comunication from my lap top to the printer. ive turned it off.. and the green light keeps flashing along with the orange intermittently,, Its driving to distraction.. HELP
    Brigadier General:
  • 6,966 Answers
I suspect that the reason that there is no communication between your laptop and printer is because the printer will not switch online. This is further confirmed by one of the flashing lights. This is a standard feature if the built-in diagnostics of most current printers tells it that something is wrong.
Since as you posted/described "I've just put in all new inks and now..." was when the problem started, pls verify:
1. the ink cartridges are seated properly at their assigned slots;
2. most ink cartridges when new have a sticker cover of some sort to protect the electronic/contact pins. Pls verify that they were removed;
3. the cover/panel doors are securely lock in place;
4. verify that the USB cable/connectors are attached;
5. you have installed the correct model of ink cartridges, they are original and not generic/replacements/refills;
6. all others are where they should be, paper in tray, slides extended and nothing out of the ordinary;
If your concern has not been corrected after completion of the above procedures, pls post back with the brand and model of your printer. it might be of further help if you can post your laptop's brand & model as well as the operating system.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 13, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer not able to print?
Printer Keeps flashing green light
Mar 31, 2010 | Canon BJC 250 InkJet Printer
My Kodak printer ESP3 is not printing. It keeps flashing over the 3 color tear drops (red,green,purple). Ive powered it on and off several of times as well as checking the cords.
This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Jan 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Lexmark z25 printer light keeps blinking, will not print
Have you used this printer before? Is it new? The flashing green light means that the ink cartridge needs to be replaced. Make sure you have the ink cartridge in correctly and seated down completely. Otherwise, it may be a defective ink cartridge.
Mar 29, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Message "Waste Ink Near Full"
Waste Ink Tank Reset
1. Turn off printer
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
No black ink
Canon S330 Turn off printer
Nov 22, 2008 | Canon S 330 InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
