Question about MSI P4MAM2-V Motherboard
No power....? when i plug the external Harddisk (seagate 80 Gb), the IDE detecting took so long, then i unplug it, the computer boot but the blue screen apply, "Begining dump physical memory" then the computer restart after that computer is dead, the power supply fan won't move, i try the power supply to other computer it's work. The RAM is fine. what's the problem?,,,please help me, Thanx's.
    Sergeant:
  • 317 Answers
Try to remove your processor, then install it again,,, be carefulll to remove it...
Posted on Mar 13, 2008
SOURCE:
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My internal harddisk locked when boot Seagate Barracuda 7200.7 ATA 40 GB
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 16, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard drive not detected what can i do
If your hard drive is not being detected the moment you startup the computer, then try to turn it off and open the computer's casing. Pull the two cables connecting to your hard disk and wait for like 5 minutes before plugging the cables back to it. Then power it back and see if it gets detected. If not, then your harddisk might have failed. You might want to check it though thru the CMOS setup if the Seagate disk drive is still on the list of the Boot devices. If not, then you can do a data recovery by unmounting the harddisk from your computer and put it as a slave drive to another computer or to an external harddisk usb enclosure.
Should you need further assitance, please let me know. Thank you for using FixYa.
Dec 16, 2010 | Seagate Computers & Internet
My segate 80gb IDE harddisk Board power and header Problem. Please Help me How to recover my data in that hard disk.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 18, 2010 | Seagate (ST980811AS) 80 GB IDE Hard Drive
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Seagate HDD external drive
set its jumpher ot the slave position and plug it on ide2/secondary port of the motherboard and dected it from bios setting of the pc which appears when u press delet/f2 buttin when computer starts.
Jun 24, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
MSI P4MAM2-V Motherboard Logo
60 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
