Question about GE Spacemaker JVM1640SJ Microwave Oven
Model jvm1330bw004 the unit still cooks but the lights and fan don't work, is the 20 amp fuse the problem?
  • howtohowie Mar 17, 2008
    yes it is the exhaust fan and cook top lights.this is on my daughter's oven and my son in-law tried to change the bulb without unplugging the unit, I think you probaly have the fix for us thank you
  • GE Master
  • 9,174 Answers
Do you mean the internal cooling fan and cooking cavity light?
I'm guessing these are not the ones you mean, but if so, please reply back and I'll address that.
I'd bet you mean the exhaust vent fan and cooktop work lights?
If you mean the latter, the problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
SOURCE:
GE microwave Model JVM1540DP1CC S/N HT931338B MFG. 5/2010. Fan comes on when door is opened. Also 20 amp internal fuse and the breaker blows if the door is opened while the microwave is cooking.
I don't have the Schematic but did you replace the fuse once? You may need a Slow Blow Fuse. They are marked and just look different
A slow blow fuse is different from a fast acting fuse in its capability to withstand transient pulse currents, i.e., it can withstand the surge current upon power-on/off, thus ensuring the equipment works normally. Therefore, slow blow fuses are often called time-delay fuses.
Hope I helped If I did please "Like"
Mike
Aug 05, 2018 | GE Microwave Ovens
The light and fan continue to run after cooking.
open the microwave cover & check micro switch attached with door lever.it may be displaced or damged. replace it
Apr 25, 2014 | Samsung SMH9187 Microwave Oven
Hi I have a Panasonic NN SN 797S. works perfectly for say 20 mins and then blows a fuse. Replace the fuse and it may work for 2 days or 10 mins and then a fuse blows again. I was told the noise filter
Is the internal cooling fan working when you cook?
If not, the magnetron will overheat, and the unit will draw excessive current.
Otherwise, I would suspect the inverter.
Due to the complexity and lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on repairing an inverter.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
The service manual is here.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Dec 01, 2013 | Panasonic Microwave Ovens
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 27, 2010 | Maytag MMV1153A Microwave Oven
I have a GE Microwave Model JVM1540LM2CS. It started making funny noises like a fan or gear grinding and then it quit working altogether. I have checked the circuit breakers in the house and have...
sounds like the mag fan went out and blew the internal fuse they are ceramic fuses 15 or 20 amp available at hardware stores ,if this blows again it could be the mag overheated,but the thermal breaker should have shut it off before this,thenit can also be your h.v. diode or capacitor shorted
Oct 10, 2009 | Microwave Ovens
It stopped working yesterday. The light works, the fan works the timer counts down if you attemp to use it but it doesn't turn on to cook. It was purchased in 05.
There is normally a fuse internally accessible that can be user replaced. Fuses can fail due to metal fatigue; the flexing that occurs when current flows and stops. The high voltage circuit customarily is fused separately from the control circuitry and the high voltage circuit needs a fairly high amperage fuse; possibly up to 20 amps.
Removing the housing generally requires the removal of a few screws (done AFTER the plug has been out for a while) and lifting off of the housing.
Look for a longish (20-25mm - ~1 inch) ceramic cylinder in some type of fuse holder. If you have any kind of multimeter at home (everyone should, they are cheap) you can check if the fuse has continuity, if not, most of the large chain hardware stores will have the replacements; buy two. If another fails, don't bother to replace it, that is a sign of another component failure.
If the magnetron hasn't shorted, a repair is marginally economical.
If you still have the warranty conditions, you might check to see if the magnetron has a longer warranty than the whole unit; they once were warranteed for 5 years but if only the fuse has failed, Sharp will probably charge for the repair.
You can buy a usable digital multimeter at Radio Shack or auto parts stores for under $20 or if near a Harbor Freight tool store, under $10.
Aug 14, 2009 | Sharp R-1510 Microwave Oven
Power went out while cooking. Now light, and fan doesn't work either. Could there be a fuse?
Assuming that you have checked the voltage/breaker at the unit, There is a fuse located behind the user interface. You must exercise caution in this area as there is a high potential for harm due to the capacitor having been energized. If you are not comfortable/experienced handling high voltage, then I would strongly recommend calling for service. Hope this helps... Bill
May 29, 2009 | Kenmore 63792 Microwave Oven
Where is the fuse located
It would be helpful if you could reply back with your brand and model number, but I can give you a good answer without it.
First of all, this won;t be a problem with the fuse. When a microwave's fuse blows, the unit will be dead.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not listed, please reply back with your brand and full model number.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
Mar 25, 2008 | Microwave Ovens
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
178 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
