Question about IBM ThinkPad R31 2656 Notebook
Powers off at random, or won't turn on at all
We have an R31 with a Pentium III 1.13 GHz processor. It runs XP Pro. Here is the problem:
-If it powers up at all, it sometimes will run way past the boot cycle for an hour or so and then shut off without warning. Sometimes it will start and try to boot up, then shut off without warning.
-If it is in the docking station, usually it will power up and stay running, unless it is moved. Then it will shut off.
-The times that it does not power up (usually when it is out of the docking station), occasionally there will be a "sizzling" noise coming from the area underneath the laptop where it docks (underneath the power button more or less). When this happens, if I press the power button, it will not power on, but the keyboard light at the top of the screen will illuminate while the power button is being pressed. Sometimes if I smack the underside of the laptop with my hand, it will stop the "sizzling" noise and might start up (but not stay running for long)
Things I have tried:
- swapping batteries, no difference
- running without a battery just plugged in with AC adapter, no difference
If anyone has ANY suggestions and/or insight to what the problem might be, I would be forever grateful! Right now the laptop is a paperweight.
Thank you so much.
Steve
  • 1 more comment
  • King Tex Mar 14, 2008
    That's what I was thinking too. There's probably dirt or something on the motherboard and/or something up with the power supply. To open, you basically have to pop the keyboard out (taking the screws out first on the bottom), right?
    Thanks
  • kenv1 Jul 26, 2008
    Same sudden black out problem, restarts again on its own. PC repair shop said not worth the price of fixing. Could be power or motherboard problem.
  • kenv1 May 11, 2010
    I have the same problem. Screen blacks out, and restarts again. Took it to a PC repair shop. Also suspected motherboard or power problem, not worth the price of repairing.
    But I would like to try to fix it myself. Is that possible? Can anyone direct me to more specific procedures? Thanks
    Genius:
  • 3,587 Answers
Hmmm..the sizzling may be some junk inside on the motherboard...you know how to open this paperweight up?
Posted on Mar 13, 2008
  • Patrick Michaels
    Patrick Michaels Mar 15, 2008
    yes..keyboard popping..make sure you use a lime when popping that keyboad(oops..that's for A Corona)
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Can u explain the growth of the pentium processor with respect to the pentium pro, pentium II, pentium III, pentium 4 and the pentiuim 5
the prcessory varies with clock speed and the speed for example a pentium 1 processor has a spped of 100mmx with aclock speed just 66mhz now the pentium 4 processor uses a spped of 3.0 ghz with a clock speed of 800mhz so there is deferance as the clock speed increase the speed of the computer increases
Aug 31, 2011 | Intel Pentium IV M, 3.06 GHz Pentium 4-M...
My Intel Celeron Dual Core E3400 Processor is running at 1200mhz, instead of 2600mhz. I tried altering all the available Bios options, but to no avail. Even more, my Windows XP x86 Professional recognizes...
Click Start
Click Control Panel
Click Power
Change the power-setting from "portable" (implying long battery life) to "desktop" (implying full speed processing, but shorter battery life).
Jun 13, 2011 | Intel Celeron E3400 / .6 GHz processor...
Is it Pentium III,1ghz processor compatible with windows vista home basic?
no I believe only Pentium 4 and up with a minimum of a 2ghz processor and 1 GB of ram is the minimum specs for vista.
Apr 26, 2010 | Compaq Pentium III , 1 GHz Processor...
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Petium 3 processor with windows xp
Just a bit of information. Your slow speed reguards to DSL is bull. Unless your ISP requires your system to run a min Mhz cpu. Cant really suggest how high you can up your cpu unless we know the model of the board & it wouldn't hurt to know the bios version too. Here is a small list from Fixya of Dells & Pent III. http://www.fixya.com/support/dell/motherboards/f5996
Jan 05, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Nov 04, 2006 | Gateway Pentium III , 600 MHz (1515824)...
IBM ThinkPad R31 2656 Notebook Logo
255 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
