Question about RCA D52W19 52" Rear Projection Television
RCA D52W17 won't stay on.
I have an RCA D52W17 HDTV and when I power it on it shows a blue screen for about three seconds then powers off by itself. Why won't it stay on?
  • jennifer hardin
    jennifer hardin Mar 23, 2008
    our tv was working fine only had it for like a year... turned it off one day and then when i turned it back on like 20 min later all it did was show a blue screen with a light blue line in it, you could hear sound but no pic, then like 10 sec later it powered itself off.... what could be the problem?
Need to find a small circet board for my RCA D52W17 TV my remote doesnt work not any remotes work any more and the problem is the small circet board
Posted on Jun 19, 2008
    Genius:
  • 1,030 Answers
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Posted on Mar 13, 2008
SOURCE:
How do I fix the red color on my RCA D52W17 HDTV ? Everything is real clear on the TV but I only get blue and yellow colors, I don't seem to get red. How do I fix this????
if your supplying an RGB signal to this set from a cable or sat box and not using its built in digital tuner id check the connections of the "R" (red) cable input this might have come disconnected
Sep 23, 2015 | RCA Televison & Video
My rca hdtv has 3 split screens
T con board responsible for images on screen. If they are messed up, check this board out or replace it.
Aug 23, 2017 | Televison & Video
I see red, blue and green on my RCA HDTV model D52W17
If it looks like three seperate images one of each color then its a convergence issue and it could be one of three things but if you send a email to [email protected] they will assist for free and help determine exactly whats happening with the TV.
Feb 09, 2013 | Televison & Video
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
D52w17 big screen tv won't power on
Thats a common problem which means the Flyback and cp150 and CP114 need replacemnt. Your model used a couple different flyback designs but the following link can tell you which one you need and they provide free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | RCA HD52W59 HDTV Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
622 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
