Question about Lexmark JetPrinter X1185 All-In-One InkJet
Printing blank pages
The printer acts like it is printing, but it is not. I only get blank pages. I have inspected my ink and had printed with this ink before.
  • 4 more comments
  • royale49 Mar 13, 2008
    Printer does not do anything, new cartridge in. Brought new computer, installed X1185 disc, nothing worked. Called support at Lexmark, gave them number on disc PN17M0265, was told disc will not install on this printer any longer.. Was told to down load disk from computer, but we can't find it. What do we do?
  • Anonymous Apr 26, 2008
    Well i have a problem. My printer(lexmark Z22 color jetprinter) seems like its printing but it comes out blank. The protective tape is removed , what should i do?
  • Anonymous May 23, 2008
    open the printer top and dig your fingers in the middle hidden nook. you will feel a tiny little lever. push the lever with your pointer finger and hold it down till you can read on the printer screen that it is ready to work. keep messing with the little lever until you reset the printer properly. this printer sucks hairy balls!!!!
  • Anonymous May 26, 2008
    exactly the same
  • yomsord Jun 05, 2008
    My printer prints blank Pages even when it indicates that the catrages are full. I have tried all I know , but still cant solve this problem.
  • seekandfind Nov 19, 2008
    I have an Epson. It was working FINE. I changed black cartridge and colors stopped printing and black stopped printing. Many cleaning cycles later, black hands from ink, paper towel cleanings, it only prints blank pages!!! help. It was fine 2 minutes before I changed the black ink.
  • 2,035 Answers
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Posted on Mar 13, 2008
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Printer acts like it is printing and there is ink in the printer but pages are coming out blank
The ink-jets that SHOULD be spraying the ink onto the paper are clogged.
Run a few "print-head-cleaning" cycles, to try to unclog the ink-jets.
Jul 25, 2011 | Office Equipment & Supplies
No ink on printed pages
Try to pull out the ink cartridges. Then after 1 minute put the cartridges on. Then it will initiate head cleaning. Just perform the head cleaning to clean clogged nozzles. Then try to print a test page.
May 10, 2010 | Brother MFC 490cw Color Inkjet...
After cleaning/maintenance, pages are still blank.
If you have just bought new carts (ink) and installed them into the printer and there is blank pages. and the printer is acting like its printing (moving from left to right) and sending paper out then i would say 99.9% it is defintally the head. On the printers that have the head built in and you insert your carts (ink) into the head and you don't print but very so often this is a common problem with ink printers the head gets clogged. If you are attached to your pinter you can take it to a print shop and have them clean the head (they have to remove it from the printer)
When buy a printer if you dont print alot i always suggust to get a printer where the head is built into the cart (ink) like hp they are more expensive to repalce the ink but you get a new head every time :)
Hope this helps
Apr 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Blank pages are printing! The printer sounds and acts like it is printing, but the page comes out blank.
Your ink levels may be low (or old and drying up), or the ink nozzles may be plugged. Replace the cartridges if you are out of ink. If you have lots of ink, you could attempt to clean the nozzles with cue-tips and a very mild vinegar-water solution.
Sep 29, 2009 | Dell Inkjet 720 Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
Mar 25, 2008 | Lexmark X1195 All-In-One Printer
Printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Jul 31, 2007 | Dell A920 InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
1,779 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
