Question about Cameras
Purchased QuickCam Pro 9000. Install Disk gets to a point of loading drivers then I get a 1722 error. Have an IBM T60 Laptop running XP.
  • vern01 Apr 18, 2008
    I did the same thing and it worked fine...thanks for taking the time to post your solution!
  • foustanas May 11, 2010
    I have the same problem
My QuickCam Pro 9000 will not work with QQ. Are
1st You download Webcam Driver.
QuickCam Pro 9000
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 05, 2010 | Logitech QuickCam Pro 9000 Web Cam
Very choppy video on HP DV7T Vista 64 bit
If you are happy with it running on a different OS try running it in Compatibility Mode
Right click on the desktop camera icon
Select 'Properties'
Select 'Compatibility' tab
Check the CM mode box and select the OS from the dropdown box
Click 'Apply' & 'OK'
May 23, 2010 | Logitech QuickCam Pro 9000 Web Cam
Cant get computer to recognize web cam
The Quickcam Pro 9000 is only compatible with PC, Windows XP SP2 at least.
If your virtual PC runs Windows 7, there is a known issue running it in Windows 7. If this is the case, I suggest to contact the manufacturer.
There is one made for MAC though; QUICKCAM vision PRO. Manufacturer's part number is 960-000254.
Hope this helps! Please don't forget to rate or vote. All the best!
May 07, 2010 | Logitech QuickCam Pro 9000 Web Cam
QuickCam Pro 9000 Web Cam: I plug in my Logitech Quickcam Pro 9000 and it wil...
It is possible your webcam is either disabled or the driver is corrupted. Try reloading the webcam software driver, reboot, and then try the free webcam test tool to check if it is working properly.
May 06, 2010 | Logitech QuickCam Pro 9000 Web Cam
When I install ligtech I get an error 1722 halh way through Need help
Disconnect webcam
Uninstall all webcam software on your computer
Restart computer
Go to the logitech website - identify your webcam - click on it and download software
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Sep 26, 2009 | Logitech QuickCam Pro 9000 Web Cam
Hi, whenever I install my Logitech Quickcam Pro 9000, it would always slow down my laptop, sometimes it would be so slow that a "low memory" would pop out. My RAM is 1.00 GB and I have already uninstalled...
The logitech software runs constantly and uses too much processing power. try plugging it in without the softwarer being installed and see if it will let you use it. If it doesn't you need to go to the logitech website and see if you can download just drivers.
Apr 05, 2009 | Logitech QuickCam Pro 9000 Web Cam
QuickCam Pro 9000 problem (Vista 64 bit)
make sure the following INF installed in %windir%\inf?
* usb.inf
* wdmaudio.inf
* wdma_usb.inf
The usb.inf is likely missing. Download it and place it in the windows\inf folder. Then remove all logitech drivers and software and re-install.
Mar 08, 2009 | Logitech QuickCam Pro 9000 Web Cam
Problem with running installation CD
If you explore the disk and find the exe. file you might be able to right click on it and click Properties. Sometimes there is a Compatibility tab that shows a list of Compatibility modes for older operating systems.
There is a chance that the camera won't fully function if you do this though so I would suggest you install Service Pack 2, as SP2 is basically the '2nd half' of xp, and will make installs much easier.
hope this helps
chris
Dec 17, 2008 | Logitech QuickCam Pro 9000 Web Cam
Cannot install quickCam v11.7
If you are using windows xp then you should download this fix from the microsoft website. http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displaylang=en
If you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Aug 17, 2008 | Logitech Webcam
Cameras Logo
83 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
