Green line I have a thin green line that runs from top to bottom of the screen. Is there an easy replacement part for this problem? I have a Sharp Aquos LC-46D64U purchased early in January 2008 but not installed until early February. I have the same problem; a vertical green line, or band, about 12 pixels wide running from top to bottom on the far right side. It showed up instantly when installed. The green stripe appears ONLY on the HD channels. My installer didn't know what it was and suggested that it was probably originating from the broadcast. I might add that when the HD channels are full-screen, there is a 2-pixel WHITE line running from top to bottom on the extreme LEFT side. I have neglected to check it out until now. In searching the problem I ran across this FixYa site. Since it is too late to return it to the store, I will have to contact Sharp Authorize Service for a fix, I hope.
  • 1 more comment
  • Anonymous Apr 22, 2008
    Have a similar problem that just started on a phillips 37 inch 37PFL5322D/37. Just purchased on 3/18/2008 and have maybe 20 hours on it. Tried it again today on a cold start after sitting all night no blue line (purplish blue like a rainbow color) more apparent on black backdrops.
    Boy sure hope this goes away or I get to see a brand new T.V. get serviced with only 20 hours on it. Wish I could take this one back and maybe consider another model.
  • Anonymous Nov 13, 2008
    I have a 50" vizio plasma with identical problem. Must be some adustment to fix this annoying problem.
  • warren32949 Jan 24, 2009
    green lines fade away after a few minutes
For SONY
Turn screen display to 'Normal" rather than 'Full pixel'
Posted on Dec 29, 2008
  • 103 Answers
Sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Posted on Mar 14, 2008
    New Friend:
  • 3 Answers
I had similar issues. I ended up having to replace the "Mother board" in my LCD HD TV. Basically a whole new screen, luckily it was still under extended warranty. Best regards.
Posted on Aug 28, 2013
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Thin Solid green vertical line in middle of TV from top to bottom
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 05, 2014 | Sharp Aquos Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
A thin green line running through screen
1.The LVDS or T-Conn panel is defect and must be replaced or 2, the panel must be replaced complete.
Aug 10, 2009 | Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Lines on screen
laptops do not have degausing thats only on rct screens what you have is a pixil problem and the lcd or plasma is in need of repair or replacement, if your laptop is under warrinety i sugjest you bring it in soon.
Sep 13, 2008 | Dell Inspiron 2200 Notebook
Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Jul 02, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Green line
Sorry, 9 times out of 10 this is a defective LCD Panel....Call Sharp customer service and the may extend your warranty.
Oct 22, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
1,999 people viewed this question
Top Televison & Video Experts
Electro Med Services...
