GE A730 Digital Camera Logo
Posted on Mar 13, 2008
Lens error my lens is stuck open and the camera won't work
  • 5 more comments
  • LorieKT Mar 24, 2008
    the lens won't stay open - it closes shut and says 'lens error'
  • Rybitski Mar 26, 2008
    My camera will turn on in playback mode, but when you turn it on in camera or movie mode it will just shut off. I updated the firmware to v 1.05 and it now says lens error when in camera mode. It makes no noise and seems like it is making no effort to pop the lens out.
  • Anonymous Jun 18, 2008
    keep receiving lens error
  • Anonymous Aug 05, 2008
    In my first I tried everything includinh a hammer it worked the same. It just didn't work at all.
  • Anonymous Aug 08, 2008
    Lens is stuck open.
  • Jeanette Rasmussen Nov 28, 2008
    camera or movie mode it will just shut off. It makes no noise
  • cqalger Nov 30, 2008
    The lens is stuck half open and the power will not come on to allow pictures to be taken.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
244
Points
I had the same problem - here's what worked for me....
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Zoom lens stuck closed
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
1helpful
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Thanks and have a nice day
Lens is stuck (halfway out) and screen shows "lens error" and won't do anything
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Camera lens cover won't open when you turn the camera on. Says "power off then on" but still stuck
This kind of problem occurs if camera dropped on floor that broke lens mechanism OR lens mechanism got dust particles that make it stuck.
Usually lens mechanism needs to be replaced to solve the issue, however, user level try to solve the problem is to tap camera on your palm a few time gently that may release stuck lens mechanism and it start working again, if that does not help then lens assembly will be replaced.
Thanks.
3answers
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
9helpful
2answers
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Top GE Cameras Experts
ZJ Limited
ZJ Limited
Bill Eager
Are you a GE Camera Expert? Answer questions, earn points and help others
