Question about Brother FAX-575 Plain Paper Thermal
Putting phone numbers into memory
Manual gone - please provide instructions for entering phone numbers into memory
  • Brother Master
  • 5,568 Answers
Posted on May 21, 2008
Need instructions on how to use ALCATEL A382G
I NEED PUK CODE FOR ALCATEL A382G PLEASE
Dec 06, 2012 | Alcatel Cell Phones
I need a manual so i enter contact names into memory
Thanks for using FixYa.
Please let us know the complete model number so that we can provide you with the manual.
Aug 28, 2010 | Uniden Cordless Phone
We have an old Unisonic model 9325 corded phone that has the capability to program phone numbers in it but cannot find the manual. Any way to get instructions on how to program with numbers?
I have an old Unisonic 9725, and the programming method for that phone may work for yours.
1. take handset 'off hook'
2. press: store
3. enter phone no.
4. press store
5. press memory button 1, 2, or 3...or 0-9
6. put handset back 'on-hook'
to use: take handset off hook, and press the memory number that applies.
Jul 03, 2010 | Unisonic (9742) Corded Phone
Add phone number to memory
I clicked on the Memory button and then the caller ID volume down arrow. I went to an empty spot and clicked on Memory again. That brought up the option to enter a name. I typed in the name and the hit the memory button again. That brought up the option to enter the phone number and then click on memory again and the number is entered on the phone. That is how to put a name in your phone book on your phone.
Jan 24, 2009 | GE 28112EE2 Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
STORING NUMBERS KX-T7750
Store a number in the phone memory
  • Press “Program” key
  • Press “*”
  • Press “ #”
  • Press “1234”
  • Press for number“001” for name “002”
  • Press “SP-Phone” key
  • Press “SP-Phone” key (de là if faut choisir le speed # on pressant sur cette clé)
  • Press “9”
  • Enter phone number (as dialed normally)
May 14, 2008 | Panasonic KX-T7730 Corded Phone
Emmerson Phone Manual EM2248
Emerson (EMSEM2646WH) I need to know how I can set up the speaker phone and in a way that will be clear and loud. I lost my manual, could you send another one to me?
thanks
Nov 05, 2007 | Emerson EMSEM2646WH Phone
Programming a number for memory
Memory
Nov 03, 2007 | Uniden Cordless Phone
How do you STOP The BLUE blinking light? the manual sucks!
Solution by tojo57 on Aug. 26,2007 was rated FixYa by Sydney00 & worked for me. Restore factory default settings & reprogram the handset (or in my case, both handsets). No more flashing blue lights.----Mrschick
noavatar_s.png By nonexpert_s.gif tojo57
Rank: Apprentice
Rating: 100%, 1 votes
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Oct 25, 2007 | GE 28112EE2 Cordless Phone
Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Oct 06, 2007 | GE 2-9438C Corded Phone
Brother FAX-575 Plain Paper Thermal Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
