Question about Sony XS-L122P5 Car Subwoofer
Subs not coming on
The 2 30amp fuses in my amp blew and my subs no longer come on. How can I fix this?
  • Anonymous Mar 13, 2008
    I already changed the fuses. The fuses are not the problem. The subs aren't coming on. The amp is working and I tested it with another sub and they worked.
Check the speaker wires in the box and make sure that they are connected
Posted on Mar 04, 2009
Get this fuses at autozone or radioshack just take an example.
Posted on Mar 13, 2008
SOURCE:
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
Why does the fuse blow Instantly?
Link for the service manual: http://elektrotanya.com/pioneer_vsx-305_405.pdf/download.html On page 50 of the manual (36 of the pdf) it says for the "Sub woofer pre-out jack (Not available on the VSX-305 model) If you want to boost the low frequencies, connect to a subwoofer power amplifier" Your model will not drive a sub-woofer with out another amp. His sub may be a powered sub?
Aug 31, 2014 | Pioneer VSX-305 Receiver
My power acoustik bamf 2200 amp keeps blowing its fuses, why?
another couple of things is a bad ground wire. a sub going bad( causing a different ohm load then before) ive run into a bad fuse link in the amp before as well
Aug 04, 2014 | Power Acoustik BAMF2000/1D Car Amp
System just got hooked a couple months ago and was listing to it loud and the sub quit working no blown fuses and amp light on but no sub it did it once before and had to turn off car to get sub back on
You probably blew out the sub, the larger speakers are more at risk to distortion are high output levels. The amp can no longer maintain its true output and begins passing voltage to the sub and the cone over travels or the winding burns out. You can try gently pushing on the sub membrane to see if it moves in and out easily, it may be stuck and you can free it up. If that doesn't work, remove from system and check the coil with an ohm meter resistance. it should read a low ohm value. If high value, it's blown and you need a replacement. It is also possible you blew the network that sends the lows to the sub and the high to the mid range and tweeters, check the sub first.
Aug 07, 2010 | Audio Players & Recorders
Amp burned out
yes you shorted the output transistors and replacing them will fix your issue. inside the amp you will find three legged transistors that mount to the amps body/heat sink. replace all of them.
good luck man.
Jan 23, 2010 | MTX Thunder 4250D Car Audio Amplifier
Subwoofer Repair
replace the sub and if it has a built in amp you may want to check the amp as well
Oct 10, 2009 | Logitech Z-5500 Computer Speakers
BLOWN FUSE?
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Sony XS-L122P5 Car Subwoofer Logo
46 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
